20 Most Recent Spectroniq Protron PLTV-32 32 in. Plasma Television Questions & Answers
There is a power button on tv, if it doesnt work u have child mode activated or just faulty tv
Spectroniq... | Answered on Dec 05, 2013
could be a bad fuse inside t.v. check outlet where t.v. is plugged in.cord on t.v. could be bad.
Spectroniq... | Answered on Oct 11, 2010
When I encounter people trying to solve HDMI-related problem, I invariably, immediately recommend switching over to component cabling. The picture is better, and there are far less issues with both HDCP and resolution switching issues.
That said, on to the problem you requested help about:
First I recommend you unplug all signal and power cables to your set and walk away for a good ten minutes. This ought to reset the brain inside your TV into thinking it is being setup for the first time. Reconnect the antenna, power and signal cabling, turn your set on, and run through the Auto Search function of your TV's on screen display setup menus, taking care that 'AIR' is selected as your TV's Tuner Mode (it will have most likely reverted back to 'CABLE'). This ought to help it find your antenna's DTV channels.
I hope that helps.
________________________________________
Protron PLTV-32 Manual Download
Protron PLTV-32 Service Manual Download
Spectroniq... | Answered on Jul 05, 2010
Tip
Download Spectroniq Protron PLTV-32 Service Manual
Would you like to download a free Spectroniq Protron PLTV-32 Service Manual?
Have you lost your Spectroniq Protron PLTV-32 Service Manual?
Would you like a digital, searchable, pdf version of the Spectroniq Protron PLTV-32 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Spectroniq Protron PLTV-32 Service Manual documentation.
I hope that helps.
___________________________________________
Spectroniq Protron PLTV-32 Manual Download
on Jul 05, 2010 | Spectroniq Protron PLTV-32 32 in....
Tip
Download Spectroniq Protron PLTV-32 LCD TV Manual
Would you like to review the features of the Spectroniq Protron PLTV-32 LCD TV ?
Have you lost your Spectroniq Protron PLTV-32 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Spectroniq Protron PLTV-32 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Spectroniq Protron PLTV-32 LCD TV documentation.
I hope that helps.
go to discount-merchant.com
Spectroniq... | Answered on May 07, 2010
Ur power supply board is dead.U have no electronics or machanicals skills at all,is that correct?Take it to the tv shop,it should cost u half of the price of the new tv to repair it.
Spectroniq... | Answered on Apr 29, 2010
Check for Bad capacitors on power supply board 1000uf 10v or 2200uf 10volts.
Spectroniq... | Answered on Jan 09, 2010
http://www.power-on.com/lcd194-3f.html
Go there. Only $60 and less than $10 to ship.
Spectroniq... | Answered on Aug 30, 2009
Sounds power supply board is bad and requires replacement in TV.
Available in Shop Jimmy and ask local TV tech for replacement if you are not comfortable with replacing power board in TV.
Thanks.
Spectroniq... | Answered on Aug 18, 2009
try this link for online manual
http://ww.retrevo.com/support/SpectronIQ-PLTV-20-TVs-manual/id/1279ci666/t/2/
it says the manual for 32" is on same site
Spectroniq... | Answered on Jun 03, 2009
no red light on tv. no power only two year old, need help.
Spectroniq... | Answered on May 19, 2009
Sometimes a universal remote wont work with a particular brand. I know the same problem exists for Emerson and Syvania tv's and many other 2nd tier brands as well. Try seeing if you can find the customer support number for your tv. Maybe you can then get the parts department in ordering an exact replacement for your set. If you cannot do so, try 1-800 remotes or their website. They will ask for your model number. Let me know if that helps.
Spectroniq... | Answered on May 03, 2009
You should try to use the Component cables. The red/green/blue cables as this will give you a better picture. Make sure your DVD player and TV will support those cable. However, the cable your using now will work. Your TV might be on the wrong input. Look for a button on the TV that says INPUT or SOURCE to change the input. It might be only on the remote control and not on the TV itself.
Spectroniq... | Answered on May 02, 2009
According to specs, the PLTV-32 supports up to 720p.
That's essentially the same as 1080i, and should work with a 1080i signal.
Spectroniq... | Answered on Mar 19, 2009
A replacement screen will cost as much as a new TV, plus they aren't as easy to replace as the ond CRT's.
Spectroniq... | Answered on Jan 26, 2009
Yeah, it can be fixed but not cheap.
Once the screen is shattered, replace the tv. You can buy them much cheaper than repairing one.
Spectroniq... | Answered on Jan 24, 2009
Spectroniq Protron PLTV-32 32 in. Plasma Television Logo
30 questions posted
Top Spectroniq Televison & Video Experts
Ekse
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Spectroniq Televison & Video
Most Popular Question
spectroniq pltv 3250 blacked out amp
  • Televison & Video
