Samsung Syncmaster 740NW vertical blue stripe
I've never opened one of these units, but I think you're right...a broken, cracked, or "cold solder joint"...had that problem on boards a lot of times. What has been assembled, should have a way of disassembling, unless the plastic was molded or glued after assembly, which is almost never the case, to my knowledge. Sometimes screws are hidden under labels, paper or metal plates, anywhere, really. If you can drop by a computer repair shop, you might be able to pick their brains about where the screws are, just depends on the person working there. Only other choice is to get the repair manual, but they're expensive and hard to locate, sometimes. Anyway, keep working on it, I think you'll figure it out!
