20 Most Recent
Niko OTP-2011R 20 in. LCD EDTV Questions & Answers
Need Power Supply
usually Lcd tv rated 12volts 3 ampers
but be careful.. check the polarity of ur lcd before plugging it.... some power supply has different polarity. good luck..
Why can't i use a
the universal remote has to be programmed first before it can it can be compattible with your television set. check on the manual for the universal remote for instructions on how to programme
I have a flat screen
It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
In the process of my
Using a different AC cord did not hurt your TV. Something more than likely happened internally during your move.
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
