20 Most Recent
Maxi-Cosi Cabrio Red Flame Reflection Infant Car Seat Questions & Answers
Replacing washed cover of I toddler car seat
Hi
Instructions on removal of carseat fabric can be found in your User Manual. If you no longer have the User Manual visit www.maxi-cosi.com and select the country you're in, then choose the carseat you have and click the Service tab to download a replacement copy.
PIERRE CARDIN BABY CARRIER
HiDue to the safety implications of the carseat harness being incorrectly fitted if the harness has been completely removed from the carseat shell it would need to be sent to engineers for them to re-fit the harness. What country are you in we can direct you to the appropriate customer care team to arrange this.
The seat tilts after correct installation with buckle
HiThis is not a realistic movement for the carseat - it wouldn't be tilted like this in an accident so it is not something that can correctly confirm a good fitting.Was the carseat fitted by a trained member of staff prior to purchase and confirmed suitable? Did they demonstrate how to correctly fit it using the seatbelt only?
We have just had our 2nd Child and strated using our current Maxi Cosi Cabrio Fix Seat with Iso Fix base. However, it has stopped clicking into the base! We know it previously worked, but the small
HiThe Maxi Cosi CabrioFix carseat can be used with the EasyFix or the FamilyFix base (both fitted with IsoFix)In the event that the seat will not click into position on the base it will need inspection / repair work.
If you're
in the UK
and the product is under 2 years old, please contact your retailer with your
proof of purchase and they can arrange for it to be sent to our engineers for
inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have
proof of purchase please contact the customer care team on 01284 413 141
Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking
it in for chargeable inspection / repair work required.
If you're
outside the UK please visit www.maxi-cosi.com
and select the country you're in, then use the "Contact Us" tab on the right
side for your enquiry to be sent through to the customer care team in your country.
Can I get replacement straps
Your Maxi Cosi CabrioFix can be fitted with new straps.Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.I hope this helps.Erwin de Raad
www.babycare.nl
Maxi cosi car seat for a quinny buggy
Go to the Maxi Cosi website, choose your carseat model and there are Instructions online. It's a bit fiddly but once you've done it once or twice you'll find it easy.
Fixing maxicosi seat to base
If you have a Cabrio Fix carseat, underneath the carseat should be two silver metal bars that slot into the base, if these are not on the carseat then you have the Cabrio model which is not compatible with the base.
I hope this helps.
Maxi Cosi Cabrio
I know they do the Black Reflection cover on Kiddicare.com. If you are looking to sell the pink cover you have I would be interested in buying it. Heres my email address, if you would like to sell it let me know.
[email protected] Many thanks.
Repair broken wire on Maxi-Cosi 2wayfix base.
Hello
In some countries Maxi-Cosi do have service centres where inspection & repair is possible. You should contact your local Maxi-Cosi office (Facebook or via Maxi-Cosi website, "Contact Us" option) They will be able to advise you.
