20 Most Recent
Brother DCP-8060 All-In-One Laser Printer Questions & Answers
How to reset toner life end message on dcp8060
The counter reset method depends on the cause of the toner life end message and the condition of the newly installed cartridge.
When a USED toner is installed the reset gear is set to IN USE.
When a NEW toner is installed the reset gear is set to FACTORY SET.
Brother DCP 8060 is displaying
After approx. 25000 pages you should replace drum unit
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the drum counter was not reset when you replaced the drum.
To reset the drum counter, follow the instructions below:
- Open the front cover.
- Press the Clear/Back key.
- Press 1 to reset.
- Close the front cover, pressing firmly on each side until they click into place.
