20 Most Recent Amana ARB8057CSR Bottom Freezer Refrigerator Questions & Answers
Zel gvy57ag compressor
how much the horse power of this model
11/17/2017 1:33:28 AM • Amana ARB8057CSR... • Answered on Nov 17, 2017
Amana freezer forms ice on the bottom. We have
When you see that ice forms on the bottom of your freezer it is most likely means that the drain hose of the fridge is blocked. You will need to take the panel inside the freezer off, clear all the ice and pour hot water into the drain hole until you hear the water coming out at the beck where the compressor is located. The next step would be running a 1/4" hose thru that hole.Good luck.www.QuickFixAppliances.ca
11/15/2017 2:34:05 PM • Amana ARB8057CSR... • Answered on Nov 15, 2017
0answers
Every minute or two we hear a clicking sound and a motor turns on for a few seconds then shuts down. I fear this is a prelude to major problems.
It sounds like your compressor is short cycling and yes that is probably a prelude to major problems. A number of things can cause this. Check to make sure your condenser is clean (it's the heat exchanger in the back) and if there is a fan for that unit make sure that is turning when the "motor" you are hearing comes on. If that heat exchanger is covered in dust you can easily solve your problem. If the fan has died, you might have the knowledge to do it. If those look ok it's probably something with the refrigeration cycle and you'll probably need an expert to figure it out in person.
1/22/2014 1:51:48 AM • Amana ARB8057CSR... • Answered on Jan 22, 2014
0answers
Is it worth it to fix an amana ARB8057CSR refrigerator? It needs a new compressor and we already replaced the defrost timer.
Why are you sure the compressor is bad? Did you have it checked?Take a look at this video to check the compressor.
10/23/2012 5:05:26 PM • Amana ARB8057CSR... • Answered on Oct 23, 2012
Red dial On A Amana bx21
If the fans are not coming on that would tell me the defrost timer=> R0131577 Defrost Timer is worn out and or stuck in defrost. Turn that red dial clockwise slowly until you hear compressor and fan restart.. If this solves turning on the refrigerator then you will need to replace the timer with the red dial because the clock inside is stuck and will contine to cause problems until replaced. Let me know if you have questions, Thanks Sea Breeze7_8_2012_6_48_53_pm.jpgR0131577 Defrost Timer
7/8/2012 7:56:55 PM • Amana ARB8057CSR... • Answered on Jul 08, 2012
Amana refrigerator not cooling
Fan motor locked up
5/19/2012 2:23:15 PM • Amana ARB8057CSR... • Answered on May 19, 2012
I have an Amana ARB8057CSR that has stopped cooling. I have replaced the capacitor and overload relay on the compressor as well as the defrost thermostat and eliment. When plugged in it sounds like th
Part of your message was missing but I do see that you did not mention the defrost thermostat=> 12001937 Defrost ThermostatChec for any loose wire or burned electrical connections and remember that the defrost thermostat is designed to be on while below freezing temperatures and once the temperaytures reach 50 degrees F the contacts in the defrost thermostat open to prevent the freezer from getting stuck in the defrost cycle for too long and also is a safety feature. Test the defrost thermostat with a OHM Meter while freezing.. Ask if you need I will be here to answer any questions you may have, rate if helpful and please ask if you need more answers, Thanks John Tripp/ AKA Sea Breeze
Possible Causes
Symtoms: Frost or ice on evaporator
1. Defrost thermostat faulty->Check defrost thermostat. Replace if failed.
2. Evaporator fan faulty ->Check fan motor. Replace if failed.
3. Defrost control faulty ->Check control and replace if failed.
4. Defrost heater remains open -> Check defrost heater continuity.Replace if failed.
5. Open wire or connector -> Check wiring and connections. Repair as necessary
6. Refrigerant shortage or restriction -> Refrigerant shortage or restriction. This will look very differen that a totally frosted over evaporator. Click here for what that looks like=> Lack of Freon 11_9_2011_11_43_59_pm.jpg
11/10/2011 4:28:40 AM • Amana ARB8057CSR... • Answered on Nov 10, 2011
To replace the secondary water inlet valve
Its easy procedure. Remove the back plate, removed the screw holding the valve, removed electrical wires and water tubing. install new valve in reverse very simple. ------ Thanks.Helpmech.
10/10/2011 9:15:58 PM • Amana ARB8057CSR... • Answered on Oct 10, 2011
Water leaking into ice cube bin and freezing.
The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
If the model number listed in your question is correct the part number for the needed water valve is 12002193 it could be purchased at your local appliance partstore or online at;
apdepot.com
partselect.com
apwagner.com
repairclinic.com
searspartsdirect.com
GENE
10/10/2011 5:02:02 PM • Amana ARB8057CSR... • Answered on Oct 10, 2011
Water leaking from the freezer
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/26/2011 1:06:26 AM • Amana ARB8057CSR... • Answered on Sep 26, 2011
2answers
Refrigerator portion (upper) continues to
Hello there,
The problem with the refrigerator is that the thermostat regulator is bad. Hereby resulting in lack of control on the refrigerator.
First check the control switches board to see if it still working, then you try to check the thermostat regulator. Those are the two major causes for such problem.
Once the two components are checked, the problem would be easily detected and what to replace will be revealed.
Hope this information washelpful.
Goodluck
Elect_Comp
8/21/2011 10:18:32 AM • Amana ARB8057CSR... • Answered on Aug 21, 2011
Where can I get new
Hello.
These are the part numbers
Freezer door 67003559
Fresh food door 12683805B
A short list of places to order online are
repairclinic.com
appliancepartspros.com
appliancedepot.com
apdepot.com
Gene
8/4/2011 2:23:49 AM • Amana ARB8057CSR... • Answered on Aug 04, 2011
How much should i sell
Hello, The best rule of thumb is to price it high and work your way from there. I could not find any of these for sale online and I'm sure you looked as well.
Wish I had more answers James
4/5/2011 4:21:22 AM • Amana ARB8057CSR... • Answered on Apr 05, 2011
Toshiba Refrigerator GR-H37ST not cool
The thermostat for the fridge is operated using a spring mechanism and it is different from the thermostat for the freezer. To fix this, open the 2 screws covering the thermostat for the fridge and pull everything out. You can see a block of Styrofoam. Pull it out carefully and you can see there is a small hole with a white thin plastic covering inside it. That is the thermostat. It may be stuck, so I recommend you to put something inside it so that the plastic covering won't block the square hole. Put everything back together, and the problem is fixed. Except that you can't control the temperature for the fridge anymore.
2/27/2011 8:19:32 AM • Amana ARB8057CSR... • Answered on Feb 27, 2011
Amana ARB8057CSR Bottom Freezer Refrigerator Logo
49 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
every minute or two hear clicking sound
  • Refrigerators
