20 Most Recent
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Questions & Answers
My camcorder says "cover is not open" but it is
This is most likely due to a defective switch inside the camera and
can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Touch panel lcd not working
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them as well as an aftermarket supplier.
When I turn on my
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Everthing seems to work, except the camera will
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Sony Handycam DCR-HC20 Can't see what you are recording
dear
u need to rate for that ...ok dude
does your camera ..fall some where ?
huhhh
if nt then get it checkd as this problem comes usually when the lens assembly of the camcorder gets faulty.
get it checkd by some proffesional person only.
Sony DCR-HC20 displays E 61:10 in upper right corner, no zoom
I can simulate this fault E61:10 by pulling out the CCD ribbon cables. This is an error that is pointed to no signal from Camera CCD assembly. Very gently remove the screws for the LCD cover assembly and remove. If you look in the upper left corner you will notice a ribbon cable connection. There is one more connection that should be checked, and it is located in the top portion below the CCD assembly. Make sure that all ribbon cables are currently attached firmly. Take specail care in opening your camera.
After turning it on, there is no display on the
If you can still work the controls from the LCD screen and see images from previous recorded tapes, but NOT see any current image thru either the LCD screen or thru the viewfinder then its a faulty CCD Image Sensor. Sony had a bad production run of the sensor chip from 2002 to 2004 affecting products from 2002 till who knows when. This affected other camera manufacturers too since they bought their sensors from Sony. A Sony "service advisory" in October 2005 would fix for "free" anybody coming forward with the problem. This freebie ended in October 2007. Mine went just last month. Cost to fix by Sony...$160 + shipping. There are quite a few non-working handycams on EBAY for an average of $15. Seems to me this was big enough to be an Official Recall.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
