20 Most Recent
RIM BlackBerry 8700g Questions & Answers
How can i unlock my blackberry 8700g in free?
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with any network, you can use your in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry like Verizon
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com/
Unlocked codes for blackberry 8700g
Remove the battery and you should see a sticker with several numbers on it behind where the battery was resting. One of these should be labeled either an IMEI or an ESN.
Contact the service provider the phone was made to be used with (AT&T, Verizon, whomever) and provide them with this IMEI or ESN. Once they have obtained the number, they can provide you with the unlocking code as well as the process to unlock it.
Puk code for blackberry 8700g
The PUK code is a lock code on your sim card. Once it has been entered incorrectly 3 times your sim card is fried. Go to your service provider grab a new sim and you should be good to go! Blackberrys save info on the device and computer not the sim so you shouldnt lose anything
Cant install my blackberry deskstop software
Hi Lambarrion,
I would like to clarify wheather you are getting any error message during the installation of BlackBerry Desktop Software.
Thank you for using ' Fixya ' and have a nice day!!
Invalid sim card
To unlock the handheld from the wireless network , you need to complete the following steps:
1. Turn all connects off(manage connection).
2. Select Options.
3. Select Advance option.
4. Select sim card.
5. Type MEPD.
6. Type MEP2.
7. Type the Unlock code.
8. Press enter.
You need to contact the customer care of the service provider for unlock code.
All customer care numbers are toll-free.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
My Blackberry 8700g is showing error 507 ..my
BlackBerry smartphone shows error 507 when all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
You need to complete the following steps:
- Open BlackBerry Desktop Manager and double-click the Application Loader icon.
- Use the application loader tool to install the BlackBerry Device Software.
I Hope it helped you.
On my BB 8700g 4.5 when I try to open SugarSync I
When you are trying to open a third party application on the BlackBerry smartphone, the following error message is displayed:
The application {
application name} has attempted to open a connection inside the firewall and outside the firewall which is not allowed by your IT policy.
This issue is caused by a restriction in the BlackBerry smartphone's firewall.
To remove the firewall restriction, complete the following steps:
On your BlackBerry smartphone, go to Options > Security Options > Firewall.
De-select Enterprise Messaging.
If this does not work, turn off the firewall by selecting Disable in the Status field. If you are not able to turn off the firewall, contact your IT Administrator as there is an IT policy restricting your firewall settings.
Hope I helped you.
Need the settings for my phone to be able to brows on the internet.
Have you previously received the settings from your mobile network provider - usually in the format of a text message. If not speak to your network provider and request these features are enabled on your phone. They will send you a text message which you normally have to save (all instructions specific for your network) will be in the text message.
How to increase signal strength of blackberry 8700g
When I lose signal strength, which doesn't take much with this device - It can sat in the same position and go from GSM to EDGE through no movement. A sure fire way is to turn the device off and then back on. This always works for me.
Another trick I have discovered is by switching networks - options/ mobile network and changing network selection mode from automatic to manual and allowing to select available networks which can take a minute or so choosing a selection and then going back in and changing back to autmatic.
