20 Most Recent
Olympus FE-250 Digital Camera Questions & Answers
The date doesn't appear on photo when printed.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
It keeps turning off
This usually means the batteries are almost dead. If rechargeable types, they can no longer hold a charge. If the batteries are fresh, try another set newly purchased.
I have Olympus FE330 and the Power button stuck in the depressed position and it turns the camera on and off.
First you need to get the button out. But if it is defect (I think it is) that won't help. Did you try to find out what is keeping the button in the depressed position? is it possible there is some dirt around the knob? Something you can remove?I don't think it is worth bringing it to a service center.If they need one hour to repair it will cost twice a new camera of that class.So when you can't get the know out, I think you should start saving up for a new camera.
Camera picture distorted Olympus fe -340 8.0 5xzoom
Could it be you changed something in the settings?
Can you see the scene in a normal way before shooting? then it look to me the sensor an the camera have to be good.
It is to much to tell you how, because you have to look that up in the manual, but, please try to set the camera in auto mode, because is you did set to in the scene mode, and than chose blurry background, or shooting through glass that could cause the distortion.
I put the link for the manual down here, in case you can't find yours.
Start at page 6 to see how to shoot in automatic.
Be aware if you shoot ready shot (anti shake) on a tripodthe pictures will be blurred to.
http://www.olympusamerica.com/files/oima_cckb/FE-320_X-835_C-540_FE-340_X-855_C-560_Instruction_Manual_EN.pdf
Replace Olympus fe330 lens shutter flex cable?
The socket for the remote shutter release cable is on the right side of the camera when facing the lens. It is about half way between the top and bottom of that side. Just plug it in and set your shutter option to use it.
Driver fe21o
Do you really want a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you ca use any photo management program such as Picasa (
http://picasa.google.com ).
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
How to delete all photos on Olympus camera memory disk while in camera
Erasing data completely [MEMORY FOTMAT] / [FORMAT]
In the settings menu you find Memory format / format choose that and confirm.
BUT!!!! before you format, check if no important data is on the card.
When you format the internal memory, your instruction manual (if still there) will be deleted, so first make a backup of that.
All new cards (or cards you use for the first time in the camera, should be formatted.
You could check the manual for more details.
