20 Most Recent Toshiba A205-S4577 Notebook Questions & Answers
My Laptop A205-S4577 is only
the battery bad none last this long ever. so replace the battery, there are like 1 million post like this hear,and at toshiba forum. and all are the same thing, 99.9% bad battery. some fail in 1 year abused. facts.
8/10/2018 5:05:03 PM • Toshiba... • Answered on Aug 10, 2018
4answers
Forgot password can't get in my laptop what can
So, you forgot laptop password, right?
11/20/2013 6:43:20 AM • Toshiba... • Answered on Nov 20, 2013
3answers
I have a Latitude D600
Write down a list of possible passwords. Try to remember which passwords you were using when you first got the computer. Alternately, try the password "administrator".
9/17/2011 5:16:57 AM • Toshiba... • Answered on Sep 17, 2011
My toshiba laptob Model #
That part costs just $5. The labor to install it will cost about $200. But if the plastic of the board on which the charger port is fitted has been damaged by the burning circuit then it can't be replaced or repaired - the laptop is indeed dead. The laptop will have to be opened to see if that is the case - that will cost you $50 at a pc repair shop.
8/5/2011 10:40:30 PM • Toshiba... • Answered on Aug 05, 2011
Sometimes my satellite A205-S4577 makes
the popping sound your hearing is actually the sound of overheated circuits with miniature sparks. And seeings as its your screen thats affected (by screen i mean display image) it leands me to believe that the video card is overheating. This could be cause its eighter the card has run loose or has cold solder. Unfortunately your card is on the main board. Have you ever openened a laptop before ? I'm guessing not .. Ok here are your choices.
1.) leave it as is until it completely goes
2.) take it to a shop and have it sorted out (recommended if you dont have experience)
3.) try it your self,,
now the fix for this involves replacing the main board, however lets open it up first and see if we can fint anything that has gone loos (cables screws etc) in the even we dont well we have to get a new board.
these instructions take you from disassemble directly to main-board replacement.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
follow them to the detail for disassemble, remember loose components or mainboard replacement.
4/1/2011 1:30:31 PM • Toshiba... • Answered on Apr 01, 2011
Toshiba SATELLITE A205-S4577 CORE 2
- possible problem with the AC power supply
- try using a different AC adapter. if issue persist try flashing the BIOS. if issue still persist then have the motherboard checked out.
3/29/2011 9:23:13 PM • Toshiba... • Answered on Mar 29, 2011
I have a Toshiba Satellite
Dear Friend,
Try this first!. Removed the battery and plug the power, press the power button. If nothing happens, unplug the power supply and press the power button for about 30 seconds (assuming that you have removed all power source, battery and power supply).
If none of this worked, try another battery. Most of the time some brands required presence of battery in order to operate. If not, may sure that your power supply is providing you with adequate power (grab a multimeter and test it, if you know how to)
Good Luck!!!
2/20/2011 7:31:02 AM • Toshiba... • Answered on Feb 20, 2011
Can't get my wireless up or use the ethernet it
hi,
you may download the proper driver from the manufacturer's support website. This is the link for your wireless card driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1702257&rpn=PSAF0U&modelFilter=A205-S4577&selCategory=2756709&selFamily=1073768663
Click on downloads tab and choose windows xp as the operating system. it will show a list that is available for download. in your case, this is the name of the driver you would like to put on your computer, Intel Wireless LAN Driver V11.1.1.16 for Windows XP(v11.1.1.16; 07-31-2007; 6.62M). I hope this works for you. Kindly reply should need further assistance. Good Luck! Mongkey "Understanding explains better..."
1/22/2011 6:00:53 PM • Toshiba... • Answered on Jan 22, 2011
Toshiba a205 s4577 sound
I had problems with Toshiba's website giving me wrong drivers. Try looking up, on device manager, the manufacturers name for the sound card and go to their website for answers.
11/2/2010 7:44:29 PM • Toshiba... • Answered on Nov 02, 2010
On boot up asks for password? have no clue!!
9/13/2010 6:09:20 PM • Toshiba... • Answered on Sep 13, 2010
My laptop computer, Toshiba Satellite A205-S4577
the only thing this could be is the backlight inverter has failed. you would be better getting a cost on the part and repair before you go ahead.
6/16/2010 8:34:50 PM • Toshiba... • Answered on Jun 16, 2010
2answers
Toshiba A205-S4777 PC NOTE BOOK Without Wall
You need to install one of the codecs.
Here is the link
6/15/2010 4:01:58 AM • Toshiba... • Answered on Jun 15, 2010
I hooked my laptop to a hard line internet and it
Assuming that you have set up the connection from that computer the next thing you want to do is check your anti-virus settings to make sure that your firewall is not blocking the connection. If you use the Windows firewall check the same thing. It seems that this is a computer issue and not a network problem because you indicated that your HP is able to connect wirelessly with no problems.
3/27/2010 6:29:56 AM • Toshiba... • Answered on Mar 27, 2010
Toshiba notebook 1905-S277 Fails to Power Up Most of the Time
I had the same problem with my toshiba a215 it ended up being the connector on the circut board need to be replaced when I did that no problem since good luck
7/14/2009 9:10:18 PM • Toshiba... • Answered on Jul 14, 2009
Starts up but screen black
check your inverter and LCD connector.
5/20/2009 3:55:37 PM • Toshiba... • Answered on May 20, 2009
Toshiba A205-S4577
Check your power settings. You might have it set to shut off after a certain time of non-use.
5/13/2009 7:19:55 PM • Toshiba... • Answered on May 13, 2009
How to unlock the laptop if i forgot my password
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
5/12/2009 4:51:03 PM • Toshiba... • Answered on May 12, 2009
Toshiba A205-S4577 Notebook Logo
43 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
sometimes satellite a205 s4577 makes
  • Computers & Internet
