20 Most Recent
Sony Cyber-shot DSC-W200 Digital Camera Questions & Answers
How to display date
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Camera is flashing
The flash fuse on the main board or flash board is bad. Contact your local Sony service center for repair as this is possibly a short circuit problem but first try this......
I found a forum that talks about your error. Here is a quote from the forum:
TO SOLVE FLASH ERROR sony cybershot ERROR CODE E:91:01 , JUST GO
TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE""""
CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL.
please rate my help++++Thanks for using FIXYA
Sony DSC-W200, 12.1 mega pixels stuck
I know this may sound a little simple but mine, though not same model, will do the same thing if the battery is not charged. Could also be a bad battery. Use this link to Sony for any other questions. https://www.sony.co.uk/electronics/support/compact-cameras-dscw-series/dsc-w200#faqs
Can't get pitcher from camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
SONY DSC-W200 HAS A BLANK SCREEN
If you have DISP/ DISPLAY button then press it 2 - 3 times and see the result. After that if the problem still same then take a snap & see it in PC. If the snap not taken by camera then its a CCD fault . If you able to see the photo in PC then its a LCD display problem & need servicing.
The camara got wet. We
I would put the camera into a bowl of rice (sounds crazy, but it works). The rice will **** the remaining water from the camera. If you are still having problems you will probably need to replace the camera.
Lcd screen has only minimal
Your camera almost certainly has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Sony service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera, or
at least are able to use the information to help decide whether to buy
another camera. If you do
decide that you have to throw your camera away then don't forget to
remove the memory card as it can be used in other devices.
Please take a moment to rate the free answer I have provided
for you and
any testimonial which you might wish to add is always welcome.
Red light by the battery
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
