20 Most Recent HP LC3260N 32 in. LCD HDTV Questions & Answers
it possibly you have bad power supply board that need to be replace or repair.
HP LC3260N 32... | Answered on Nov 04, 2012
Hello, it's not PiP that's on , it[s a closed caption issue. the CC is in the text mode and is an easy fix. just press the CC button on the remote (it's located above the 1 button) till it says off on the tv screen, or if you use closed caption select CC1. this should take care of your problem......thanks, Terry
HP LC3260N 32... | Answered on Sep 24, 2012
So Brad Brown, if this is what is broken and you take it to a repair shop, what would you expect to pay? I am trying to decide if it is worth it if the TV is 6 years old and we could go get a new one for $350.
HP LC3260N 32... | Answered on Sep 16, 2012
Ok, this may be a simple Format, error, First, check it is in right Format, IE: NTSC, USA, PAL, everywhere else.
http://www.retrevo.com/support/HP-LC3260N-TVs-manual/id/276ag402/t/2/
http://www.scribd.com/doc/6982139/LC3260servicemode
Troubleshooting manual above.
http://personafile.com/Hewlett-Packard-HP-Television-LC3260N-32-inch-High-Definition-LCD-TV-EL514AA%23ABA-P0829160001315.htm
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else
HP LC3260N 32... | Answered on Apr 13, 2010
Check 20V output of power supply that goes to back light inverter board, if volts are available then replace back light inverter board.
Click Shop Jimmy to see an image of back light inverter board that is available for $50
back Light Inverter board would be located at right side of lcd panel and usually covered.
Please post an image of rear of your tv so I can point out it in that image.
Hope his info will help you.
Thanks.
HP LC3260N 32... | Answered on Feb 14, 2010
Try code 1088
HP LC3260N 32... | Answered on Jul 01, 2009
All HP iq77x all-in-one PCs suffer from the same problem of a faulty motherboard. This is primarily a soldering issue on the graphics chip,which develops cracks in the solder balls. The PCs contained a separate graphics card, which goes faulty first. This can be removed and the display connector can be moved on the motherboard to use the on-board graphics. This will eventually show the same issue. A short term fix was to heat the graphics chip with a hot air gun or other means (plenty of suggestions can be found on-line) which sometimes works for a few weeks at most. The only 'permanent' fix is to have the chip professionally removed and re-soldered; an expensive option.
If you are lucky, your PC is still wired to use the add-on graphics card, in which case you might be able to remove this and rewire for the motherboard graphics.
HP Televison &... | Answered on Mar 21, 2019
look on your f buttons f5 on mine
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview./
HP Televison &... | Answered on Nov 08, 2018
The first thing to do is go into the device manager and delete the drivers for the display and let windows reinstall them. It may be a bad or out of date driver. So when you restart the computer it will put the driver back. Since you did not post the operating system, there is not a lot more I can tell you. If this does not help, you can try an external monitor to see if the problem is present there. If it is then it may be a display chipset issue.
HP Televison &... | Answered on Jul 15, 2018
HP LC3260N 32 in. LCD HDTV Logo
15 questions posted
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • HP Televison & Video
Most Popular Question
turn off pip hp lc3260n
  • Televison & Video
