20 Most Recent Haier HLH406BB 40 in. LCD HDTV Questions & Answers
How do i make tv picture fit whole screen??
your select button on your remote, then you just go to exspand.
11/27/2015 8:30:17 PM • Haier HLH406BB... • Answered on Nov 27, 2015
2answers
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
6/19/2015 3:55:10 PM • Haier HLH406BB... • Answered on Jun 19, 2015
Haier Hlh406bb
Check the outside antenna ,if you have one for direction it may have swung round,or the set could have Copt a surge,fit a surge board to mains power.
7/26/2014 11:18:30 PM • Haier HLH406BB... • Answered on Jul 26, 2014
0answers
When it worms for 15-20 it shuts of
Main power supply regulator board [SMPS] fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/27/2014 4:34:47 AM • Haier HLH406BB... • Answered on Mar 27, 2014
My Haier flat screen has green light but won't
j'aimerai avoir un screen pour mon Haier HLH406BB 40 in. LCD HDTV
12/19/2013 2:29:02 PM • Haier HLH406BB... • Answered on Dec 19, 2013
Ecran bleu pendant quelques secondes au demarrage
j'aimerais avoir un ecrant pour mon Haier HLH406BB 40 in. LCD HDTV
12/19/2013 2:28:14 PM • Haier HLH406BB... • Answered on Dec 19, 2013
Wont power on
Check and replace its main power regulator board as card basis. It will be better to replace it as a unit, rather than trying to make it repaired. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/3/2013 1:03:04 PM • Haier HLH406BB... • Answered on Nov 03, 2013
The Sound just quit
First check speakers with multi meter. Will be 4 or 8 ohm. If they check good, bad audio output ic on main board. Hard to replace, they are an smd ic. May have to purchase main board.
11/21/2011 4:57:56 AM • Haier HLH406BB... • Answered on Nov 21, 2011
Loud pulsating noise when the
You may have bad power supply DC voltages, or it is turning on/off in cycling mode if it detects shorted circuits.
Please read my guides to get some understanding.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find.
3/11/2011 4:04:08 AM • Haier HLH406BB... • Answered on Mar 11, 2011
My Haier HLC26B-B is getting
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
1/17/2011 8:36:29 PM • Haier HLH406BB... • Answered on Jan 17, 2011
WHEN I TURN MY TV ON IT FLASH AND THEN AFTER 10
All you need to do is to open the back cover of the television to check for bulged capacitor , dry soldering.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
Hope this helpout.......
10/15/2010 12:59:35 AM • Haier HLH406BB... • Answered on Oct 15, 2010
Power suuply problem
You can get a replacement power supply from www.partstore.com but I would not recommend you attempt the repair yourself unless you have done similar repairs in the past.
9/14/2010 3:28:42 PM • Haier HLH406BB... • Answered on Sep 14, 2010
I have a haier tv
Reset the tv by unplug,replug it in an hour later.Same problems,power LED light indication flashes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
8/7/2010 10:24:14 PM • Haier HLH406BB... • Answered on Aug 07, 2010
Haier HLH406BB 40 in. LCD HDTV Logo
51 questions posted
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
HL Haier
  • HL Haier
Most Popular Question
sound just quit
  • Televison & Video
