20 Most Recent HP Deskjet 2330 InkJet Photo Printer Questions & Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
HP Deskjet 2330... | Answered on Mar 04, 2010
press and hold the power button of your printer for 20-30 sec and make a copy if still the same issue occurs the proiblem is with the printer
try the step
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01296418&tmp_track_link=ot_recdoc/c00859572/en_us/c01296418/loc:2&lc=en&dlc=en&cc=us&lang=en&product=1827327
if nothing happens
contact HP and they will probably replace the printer for you
HP toll free number -1800-474-6836
hope your issue gets resolved
thanks
regards
hamid
HP Deskjet 2330... | Answered on Feb 20, 2010
go to start >> click on run>>type "cmd" without quotes in box
command prompt opens type>
net stop spooler
and hit enter
net start spooler
and hit enter
go to the printer icon >> Right click>> Cancel ALL documnts
select yes
disconnect the usb
reconnect it back
and print
HP Deskjet 2330... | Answered on Sep 14, 2009
Head to www.canon.com and download the driver for your operating system the model printer you have. Not only will you get the latest driver for your device, but the download is free. Good luck to you.
HP Deskjet 2330... | Answered on Mar 22, 2009
go to the following link and select your OS:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1827327&lc=en&cc=us&dlc=en&submit.y=5&submit.x=7&lang=en&cc=us
* please rate me :)
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
HP Deskjet 2330... | Answered on Dec 10, 2008
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
You need both cartridges to run your printer.
HP Deskjet 2330... | Answered on Dec 02, 2008
check it`s sensor
HP DeskJet... | Answered on May 15, 2019
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
HP DeskJet... | Answered on Apr 23, 2019
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
HP DeskJet... | Answered on Nov 28, 2018
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
HP DeskJet... | Answered on Oct 11, 2018
plug it into the wall
plug it into the computer
go to printers ad devices
go to add a printer
install the cd or usb stick
and follow the installer wizard instructions
All in the operators manual for the printer
HP DeskJet... | Answered on Sep 20, 2018
HP Deskjet 2330 InkJet Photo Printer Logo
12 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
will not print nor delete printing job
  • Office Equipment & Supplies
