20 Most Recent
Panasonic NV-GS230 Mini DV Digital Camcorder Questions & Answers
Need Driver for Panasonic nv-gs230 Camcorder Software to download
You should be able to just plug a USB into the camera connect it to your computer.
The camcorder should come up as an drive in "MY computer"
Try renaming any video that are named *.moi to *.mpg
if they wont play.
Hope this helps.
Sketchlab.com
Mugshot Collection
8/12/2011 8:49:44 AM •
Panasonic...
Answered
on Aug 12, 2011
I need to copy video
Connect with a firewire cable and open Windows Movie Maker, you should not need additional drivers or software.
5/27/2011 8:56:24 AM •
Panasonic...
Answered
on May 27, 2011
I BOUGHT A FIREWIRE 4PIN
Open Windows Movie Maker and have the camera set to VCR mode, that's the one thqat replays the tape.
Try again.
3/26/2011 4:08:07 AM •
Panasonic...
Answered
on Mar 26, 2011
What kind of cable for
A firewire cable with a full size firewire on one side and a small rectangular one on the other side.
3/8/2011 6:49:09 PM •
Panasonic...
Answered
on Mar 08, 2011
Black horizontal lines on playback.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/4/2010 5:44:17 PM •
Panasonic...
Answered
on Sep 04, 2010
How to change my pal video into ntsc
After capture while using < winDVD creator 3 > program and edit movie, in the end you can choose in what kind you want to have your final video file and you can choose PAL or NTSC
10/16/2009 6:14:45 PM •
Panasonic...
Answered
on Oct 16, 2009
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHzMeaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
10/14/2009 8:11:00 PM •
Panasonic...
Answered
on Oct 14, 2009
