20 Most Recent
Lexmark X342n All-In-One Laser Printer Questions & Answers
Lexmark x342
Please log on to your network printer via Internet Explorer you will get full history. [in place of address type the ip address of printer]
Regards
rafique
Lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance.
NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information,
click here.
We have a Lexmark X342n All in one device. We have
After powering up the printer, press Menu, * key, # key (do not hold them, just press and release). You should see a secret menu, the first option being "Serial number". From there, I scrolled down to Network menu -> NVRAM reset to reset the network card. There also seems to be a Utilities menu which allows a full system reset.
My lexmark is displaying 936.03 service transport error. How do I correct the problem?
http://support.lexmark.com/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=SO1912
Quoting from
support.lexmark.com above:
Problem
Error: "936 Main Drive Motor"; Error: "936 Transport Motor"; Error: "937 Main Drive Motor"; Error: "937 Transport Motor"
Environment
The
936 and
937 error codes indicate that the printer thinks there is a problem with the main drive motor.
Solution
- If your printer is posting one of these errors, turn it off and let it sit powered off for at least a minute.
- While the printer is off, open all of the doors and covers on the printer. Also remove the toner cartridge. Make sure there is no paper jammed in the printer. Pay close attention to the area where the toner cartridge sits. The main motor is located just to the left of the toner cartridge.
- If nothing appears to be wrong with the inside of the printer, reinstall the toner cartridge and close all the doors and covers. Now power the printer back on. If the error does not return, try printing again.
- If the error does not return when you print, continue using the printer. If the error does not return after a few days, this may have been an isolated incident and the printer should be fine.
