20 Most Recent Disney Tink Digital Mix Stick MP3 Player (61692) Questions & Answers
2answers
Charge
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
7/23/2013 7:39:37 PM • Disney Tink... • Answered on Jul 23, 2013
I have been charging this
It is one of two things:
1. The power for whet the stick is plugged into is lower that the "Full" power level of the battery
2. The battery is old.
My bet is on number one as the previous owner says that it worked fine. Try a different power source.
8/24/2011 1:52:39 PM • Disney Tink... • Answered on Aug 24, 2011
0answers
I am having trouble turning my mp3 disney pix
that is a program failure.reinstalling the program will correct the problem
check also the song capacity of the memory erase some files to lessen the load
erase also corrupted program this will cause the system to hang..
1/24/2011 2:07:39 AM • Disney Tink... • Answered on Jan 24, 2011
How do I charge my mp3 player
U take off the bottom cap and plug it into ur computer
8/3/2010 8:07:05 PM • Disney Tink... • Answered on Aug 03, 2010
0answers
Won't play all songs
Possible that the files have been saved inthe wrong way. If you have them again in the PC , delete off all the files you had sent, format th device or erase off all files, scan for any virus in the device before loading back the music files with the PROPER METHOD OF COPY AND SAVE, USE THE RECOGNISED PROGRAM for the ipod- the ones the songs are playing presently. Helpful? good day
7/5/2010 5:38:52 AM • Disney Tink... • Answered on Jul 05, 2010
2answers
Can't play preloaded mix clips
Im not sure what are you trying to say by mixed..clips...but judging by the small size of the mp3 player ..I will assume that is just an old model ..and I will advice you to load only mp3 files into it ...not wma...wave or any other music file format ..cause it will not work ...and if you are trying to make something like a mix music file into a program on the computer and load into it to listen ...you have to save it in mp3 format alone ....newer models supports wma files and even old cd-tracks that used to be played only on cd players ( clasic) ...but this one is not that advanced.. ..and will only play the mp3 files..
so ...make sure all your files are mp3 ...and are not corrupted...for this ...just hook it on the computer ...copy all content into a folder ..and analyze them by right click and properties...there will show the file format ..speed and all..
1/28/2010 12:50:07 AM • Disney Tink... • Answered on Jan 28, 2010
2answers
Blinking light
Conect it on a pc & it will charge.
12/30/2009 5:37:15 PM • Disney Tink... • Answered on Dec 30, 2009
Disney Mix Sticks Unable to Remove songs
works best when u add and delete from a music program like windows media, and go to sync tab
u can add them and delete from there
6/1/2009 5:11:24 AM • Disney Tink... • Answered on Jun 01, 2009
Instruction Manual for Disney Sassy Pixie
You can download your manual there.
http://digiblue.com/customer-service/downloads/index.html
4/1/2009 7:53:37 PM • Disney Tink... • Answered on Apr 01, 2009
Disney mix stick software
You don't need the disk that came with the Mix Stick. It's just a plug in that interfaces with Windows Media Player and it completely optional. Without the software you can still use the Sync function in Windows Media Player to synchronize songs to the player.
3/16/2009 12:04:52 AM • Disney Tink... • Answered on Mar 16, 2009
Mix Stick not compatible with Vista
The help site on the box isn't a valid address, but I found the answer at www.digiblue.com. The software isn't compatible with Vista so I was not able to put my music in "mix it" format, but I was able to drag my music onto the stick like a flash drive. It works great, but I am not able to use the "mix it" feature on the stick itself. No big deal. :-)
12/31/2008 12:56:13 PM • Disney Tink... • Answered on Dec 31, 2008
How long does it charge
Make sure that is turned on.(switch to the red side) Then once connected to USB port, it will start blinking red and green.Once fully charged the light will remain red. It takes about 2.5 hours to fully charge.
11/29/2008 9:42:28 PM • Disney Tink... • Answered on Nov 29, 2008
Blinking light
That means that the mp3 player is charging. Once fully charged, the light will remain red.
11/29/2008 9:27:47 PM • Disney Tink... • Answered on Nov 29, 2008
Won't turn on
did you ever find a number or anything for this problem.. i am having the same and was curios..
[email protected]
3/28/2008 3:01:45 AM • Disney Tink... • Answered on Mar 28, 2008
Disney Tink Digital Mix Stick MP3 Player (61692) Logo
32 questions posted
Top Disney Audio Players & Recorders Experts
Alexander
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Disney Audio Players & Recorders
Most Popular Question
am having trouble turning mp3 disney pix
  • Audio Players & Recorders
