20 Most Recent
Philips 26PF5521D 26 in. HD-Ready LCD Television Questions & Answers
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
10/4/2013 2:52:00 PM •
Philips...
Answered
on Oct 04, 2013
Television is 6 years old.when
Hi:
Have the power supply checked for leaky or bad buldging capacitors on it. This is the most common reason most LCD televisions fail. Also you may have a bad backlight inverter board.
5/22/2011 5:29:39 PM •
Philips...
Answered
on May 22, 2011
Ref: 26" 26PF5521D model. Following
I'm afraid the electronics have been 'spiked' by the lightning. It may have affected more than one module There is little you can do other than having it looked at by a professional, however you may be able to claim on your insurance?
Regards
2/4/2011 1:00:00 PM •
Philips...
Answered
on Feb 04, 2011
Ref: Philips LCD DVB 26"
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
2/3/2011 7:30:33 PM •
Philips...
Answered
on Feb 03, 2011
I have a philips lcd
try changing channels, usually it turns on this way. I turn it on by clicking the up channel arrow.
1/20/2011 6:02:30 PM •
Philips...
Answered
on Jan 20, 2011
Sound fading away
I would not think the speakers are defective but rather faulty capacitors in the power supply circuitry if the TV works good for some time.
6/20/2008 7:05:04 PM •
Philips...
Answered
on Jun 20, 2008
Green line down centre of screen
Defective or Bad LCD panel.
IT will be cheaper to get new TV than to get it replaced. U can check with local repair shop or look for a panel yourself at parts.com for the price of a new panel.
5/3/2008 7:33:53 PM •
Philips...
Answered
on May 03, 2008
Vesa screw holes
Most wall brackets are universal for a particular vesa standard, in this case 100mm x 200mm.
This means that the bolts supplied aren't for any particular set.
The Philips 26PF5521D only needs bolts up to about 12mm long.
Try shorter bolts.
3/14/2008 5:05:44 PM •
Philips...
Answered
on Mar 14, 2008
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
3/3/2008 3:16:16 AM •
Philips...
Answered
on Mar 03, 2008
26" Philips HD ready tv (LCD)
Nothing much you can do. The soft plastic will get worse if you try anything.
The screen could be replaced, but would cost more than the TV.
2/22/2008 12:36:45 PM •
Philips...
Answered
on Feb 22, 2008
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
2/22/2008 12:35:28 PM •
Philips...
Answered
on Feb 22, 2008
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
