20 Most Recent Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP Questions & Answers
Coils keeps icing over
there is a disk that is attached to your coil, it controls the defrost timer in your fridge. that might be a problem or you might need a new defrost timer. hope this helps put you on the right track
2/21/2013 5:21:06 AM • Amana 25.8 cu.... • Answered on Feb 21, 2013
Amana side by side stopped cooling and hearing clicking from compressor when I turn it back on
Compresser is low in coolent, Or a Problem with the (Compressor) From what i can make out from your info. How old is this (Fridge)?
10/9/2012 1:32:06 AM • Amana 25.8 cu.... • Answered on Oct 09, 2012
I have an amana refrigerator
6/2/2011 5:35:58 PM • Amana 25.8 cu.... • Answered on Jun 02, 2011
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
5/27/2011 1:47:37 AM • Amana 25.8 cu.... • Answered on May 27, 2011
I have an Amana refrigerator model#SRD22S5W.
There is a solenoid in the back where the water line tie in. If the solenoid is bad, no water will get to either. As someone is trying to dispense water, hold a metal object (like a screwdriver) to the top of the round part of the solenoid. If there is some magnetic resistance, then the solenoid is good. If not, replace it.
5/8/2011 3:34:16 PM • Amana 25.8 cu.... • Answered on May 08, 2011
Milk freezes in the door shelf but the temp is at
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
12/12/2010 4:52:10 PM • Amana 25.8 cu.... • Answered on Dec 12, 2010
Freezer icing up around ice dispenser
need model #
8/27/2009 5:05:47 AM • Amana 25.8 cu.... • Answered on Aug 27, 2009
Amana ice maker clicking - still makes ice just really slow
level the refrigerator. i/m not level causing it to jamb and cause low ice production
8/27/2009 5:04:22 AM • Amana 25.8 cu.... • Answered on Aug 27, 2009
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
8/14/2009 2:30:42 PM • Amana 25.8 cu.... • Answered on Aug 14, 2009
Broken light switch on fridge door
Any appliance parts store can get this switch.
Yes you can DIY. Take a butter knife and CAREFULLY pry the broken switch from the cabinet. Be careful not to scratch the plastic liner around the switch.
Remove the 2 wires, place them on the new switch and POP the new switch in place.
If this is a half-moon switch make sure it is installed in the correct direction.
5/24/2009 2:30:17 PM • Amana 25.8 cu.... • Answered on May 24, 2009
Ice cubes melted, but items at the bottom are still cold.
I believe you solved your own prob.. definitly sounds like the fan motor stopped.
5/16/2009 4:00:17 PM • Amana 25.8 cu.... • Answered on May 16, 2009
My ice maker can't make ice.
Sounds like the water may be off to your unit or the solenoid is not opening to feed the water to the ice maker.
5/16/2009 2:39:35 PM • Amana 25.8 cu.... • Answered on May 16, 2009
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
5/5/2009 10:55:01 PM • Amana 25.8 cu.... • Answered on May 05, 2009
2answers
Light inside the Refrigerator will not go out when the door close
your door has dropped.need bottom spacer for door hinge.
3/12/2009 2:07:33 AM • Amana 25.8 cu.... • Answered on Mar 12, 2009
Amana SXD2252 side by side ice maker stopped, now leak on floor
ck here... https://www.appliancepartspros.com/repair-help/amana-refrigerator-sxd22s2w-repair/sxd22s2w-leaking.html But before throwing parts at it give their tech 877# a hollar.. Best to you
9/4/2023 5:56:53 PM • Amana... • Answered on Sep 04, 2023
Amana ARB1917CSR 18.5 Cu. Ft. Plus Refrigerator. What is the HP of my compressor, which Supco relay and run capacitor?
What tends to happen is that service techs have certain common generic parts in their van, and rather than ordering a part to fit and have a return visit, they fit what they have. Parts seem to be readily available. The compressor is listed but no HP Specs. The bottom show another model and that R134A (1/4HP) is different to R134 (1/5 HP). https://www.google.com/search?q=amana+arb1917csr+parts+diagram https://www.google.com/search?q=Tecumseh+TP122AR003B8 ..
7/27/2023 6:43:23 PM • Amana... • Answered on Jul 27, 2023
3answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM • Amana... • Answered on Jun 20, 2023
Refrigerators Logo
21 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana side side stopped cooling hearing
  • Refrigerators
