20 Most Recent
Samsung SyncMaster 203B LCD Monitor Questions & Answers
Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine
what's wrong with your LCD monitors. After you turned it on and the screen
blacked out or stopped working, you have to check that if you can see the image on the screen or
not by shining a flashlight into the screen, not directly but find the best
angle to the screen and take a look very closely. If you can see the icons or
any image, there will be a minor problem. This is because of the lamps inside
screen. Some of them were broken and it is very easy to replace. If you cannot
see anything on the screen, there'll be some problems with inverter board. If you
have soldering tool and want to fix it by yourself, check the caps first. It
may cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
9/12/2019 2:02:24 PM •
Samsung...
Answered
on Sep 12, 2019
My samsung syncmaster 203b, the screen has just
This model is a great one and well worth repairing. The display problem you are having is caused by bad capacitors on the power supply board. To repair the unit you will need to replace 6 capacitors and one fuse on the board, this is very easy to do, it just requires a little soldering. Here is a picture of the power supply board with the capacitors and the fuse circled and here is a link to additional information on the capacitors needed.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
1/22/2018 4:10:05 PM •
Samsung...
Answered
on Jan 22, 2018
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
8/29/2013 5:38:28 AM •
Samsung...
Answered
on Aug 29, 2013
Samsung syncmaster 203b problem
Hello,This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
9/7/2012 3:31:30 AM •
Samsung...
Answered
on Sep 07, 2012
Monitor flickers on start up after shut down
Hello,The symptoms you have are very common on this model. The capacitors in the power supply are beginning to fail and as this happens they can not filter the power correctly and you get the flickering until the unit stabilizes. As time go by the issue will get worse until the unit fully dies. The repair is very easy, you will just need to replace 6 capacitors on the power supply board. Here is a link to additional information on repairing this model.
http://www.ccl-la.com/catalog/product_info.php?products_id=229I hope this helps, BuddyMc
9/7/2012 3:09:06 AM •
Samsung...
Answered
on Sep 07, 2012
Nothing on the screen
if their is a an power indicator in the front but with out a display or black screen, the cause it could be a busted back light or dry joint connector for inverter board for screen back light.
8/16/2012 6:35:46 AM •
Samsung...
Answered
on Aug 16, 2012
