20 Most Recent Hitachi 42HDT79 42 in. Plasma Television Questions & Answers
Hello, I wanted to change the
If the tv was on when you unhooked it there is a cooling fan that didn't get to cool off the picture box and it has overheated and you will have to replace the box you can order it off of eBay it takes a few moments to replace it if you still have your owners manual it will tell you all about the lights on the front of your tv I've had to change mine out a few times hope this helps Merry Christmas
12/3/2017 3:25:40 PM • Hitachi 42HDT79... • Answered on Dec 03, 2017
0answers
Why doesn't it turn on?
Try changing the fuse in the plug or making sure the power lead is pushed in the tv maybe a difrent socket. if these are ok then there is some thing wrong with the TVs its self could be a number of things better of taking it to a shop to be looked at !! Hope this helps !!..
10/12/2015 3:27:51 PM • Hitachi 42HDT79... • Answered on Oct 12, 2015
Where do I attach audio output for headphones.
Excuse me brother, but if you have the owner's manual and the TV set in front of you, actually you are in a better position to find audio output. I don't have YOUR manual. Anyway, you can download one from the link I'll provide you, maybe it is more explicit then the one you have Look at REAR panel and search for word "AUDIO OUT". If the plugs of your headphon won't fit AUDIO OUT connections take it a photo and go to a computer parts shop with your headphones ans purchase the appropiate converter http://www.hitachiserviceusa.com:8080/55HDX99.pdf
5/10/2015 3:48:16 PM • Hitachi 42HDT79... • Answered on May 10, 2015
Hitachi 42hdt79
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/6/2014 2:08:36 PM • Hitachi 42HDT79... • Answered on Aug 06, 2014
There is no red standby light on my hitachi 42pd7200, how do I get tv screen on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
4/22/2014 6:30:26 AM • Hitachi 42HDT79... • Answered on Apr 22, 2014
0answers
0answers
My 42hdt79 will only work on inputs. The air is just static
Hi how can i fix muy tv its on standby
2/4/2014 2:26:26 AM • Hitachi 42HDT79... • Answered on Feb 04, 2014
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
2/4/2014 2:24:53 AM • Hitachi 42HDT79... • Answered on Feb 04, 2014
42hdt79 upgrade
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
1/7/2014 3:24:05 PM • Hitachi 42HDT79... • Answered on Jan 07, 2014
Tv wont turn on
check all electrolytic capacitors (cans) in the power supply (the board the mains connect to for flat tops (if the can has a rounded top it has failed and, must be replaced
2/4/2013 5:59:19 PM • Hitachi 42HDT79... • Answered on Feb 04, 2013
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
11/22/2012 6:15:49 PM • Hitachi 42HDT79... • Answered on Nov 22, 2012
Fuse is blowing on power supply
A blown fuse is indicating a short in the power supply. The power board will most likely need replacement. You can get the replacement power supply board from www.tvcircuitboards.com
11/8/2012 10:04:46 AM • Hitachi 42HDT79... • Answered on Nov 08, 2012
Where is the fuse located inside the hitachi 42
check at the power supply board.
8/19/2012 3:34:04 AM • Hitachi 42HDT79... • Answered on Aug 19, 2012
I have my Hitachi 42HDT79 42 in. Plasma Television on my wall and I have no voice, just a loud squeeing noice
It of course may be a audio problem in the set (main board) but is a box or anything external being used for sound on the set? Same problem with a DVD etc the only thing connected to the set?
6/6/2012 6:51:36 PM • Hitachi 42HDT79... • Answered on Jun 06, 2012
Hitachi 42HDT79 42 in. Plasma Television Logo
84 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
42hdt79 will only work inputs air just
  • Televison & Video
