20 Most Recent JAKKS Pacific Ms. Pac Man Plug And Play Tv Video Game Jakks Namco Questions & Answers
Absolutely, if your not electrically inclined take it to your local electric repair shop. It shouldnt cost much,
JAKKS Pacific... | Answered on Jun 05, 2014
Write your answer...I have the manual book but its difficult to set my Dixon RM-L600 Universal Remote Control please help me how to set it on My Hisense 32LD
Televison &... | Answered 1 hour ago
you can try looking up utube vids of this to find out more about your model, also you can google it, also you can check this website for the new version of tv thats easyer to use and lets you download apps as well its the Roku tv you can find the here at discount prices>>>www.discountbargainprices.com
Televison &... | Answered 3 hours ago
Hello Daniel, ask, what kind of Leds did you use, did you replace the Leds strips that were wrong, for others of the same type and model or did you use generic strips or did you just replace all the LEDs, one by one and if you did this, you respected the Working voltage of each Led?
Another question, when you armed, did you put the soft plastic panel that is the reflector of the light of the LEDs?
I ask you all these questions in order to find the source of the problem and find the best possible solution
Also discuss the brand and model of your TV
I await your answers and some more comments about what you did
Greetings Franco Dosil
Hola Daniel, pregunta, que tipo de Leds usaste, reemplazaste las tiras de Leds que estaban mal, por otras del mismo tipo y modelo o usaste tiras de les gen?ricas o simplemente reemplazaste todos los Leds, uno por uno y si hiciste esto, respetaste la tensi?n de trabajo de cada Led?
Otra pregunta, cuando armaste, pusiste el panel pl?stico blando que es el reflector de la luz de los Leds?
Te hago todas estas preguntas para poder encontrar el origen del problema y encontrar la mejor soluci?n posible
Comenta tambi?n la marca y modelo de tu TV
Espero tus respuestas y alg?n comentario mas al respecto de lo que hiciste
Saludos Franco Dosil
which thing you are connected with your TV..
Televison &... | Answered 12 hours ago
Many computers can play many file formats,
BUT...
Not all DVD players can play all files.
What file format is the slide show saved as?
AVI?
Download a freeware conversion program (if you don't have one) and try another format.
My latest DVD player plays about six video formats, JPG images, but battles with AVI, due to it's many variations of format (dimensions, resolution, color, frame-rate, interleaving, etc).
WHO CARES IF YOU CAN NOT READ THEN YOU DO NOT NEED THAT INFORMATION
Televison &... | Answered 14 hours ago
are you using remote if. no. then use remote for turn on..
connect with witch thing.....
Televison &... | Answered 15 hours ago
Hello AL, indicate the brand and model of the TV you are commenting, in order to find the best possible solution
I wait your answer
Hola AL, indica marca y modelo del TV que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Televison &... | Answered 16 hours ago
Ok have the same TV and it did the same thing stunk on the Android screen, To fix this i powered of the tv so it was in standby then above the RJ45 connector on the side of the tv you will see a update key (Find a pin or small screw driver ) then press and hold the button that is in the update key and whilest holding it power the tv on. Once you see the android robot with his shell open you can let go and it will come up with a list of options, select the reset all user data files to factory restore then select the restart system now, once all that is done give it a moment to boot back up as normal and it will allow you to set up like the first time it was turned on, :)
JAKKS Pacific Ms. Pac Man Plug And Play Tv Video Game Jakks Namco Logo
1 questions posted
Top JAKKS Pacific Televison & Video Experts
Marvin
Marvin
Are you a JAKKS Pacific Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JAKKS Pacific Televison & Video
Most Popular Question
split white cord ms pacman tv game
  • Televison & Video
