20 Most Recent
HP Officejet Pro K5400 All-In-One InkJet Printer Questions & Answers
Why is my HP printer not printing Black in black.
may be the ink cartridge is empty/not working. remove and return then restart the printer. if empty u can buy a new one. if u are a risk taker buy the black ink then a seridge and a niddle then refill it.
How can I reset an HP C9381 head?
If your printer is reporting that a print head need to be replaced, then you really have little choice. These are Yellow-Black and Cyan-Magenta dual colour heads and are only available from HP as a service part. You will need to supply HP with the model and serial number of your machine. It is possible to clean the printheads and you can buy a clever device for flushing cleaning fluid through them to clear out blocked jets, but please note this does not bypass the built in recognition codes for new heads.
Magenta light flashing
Check your lights , this printer has a user replaceable print head as well as the ink cartridge http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00844061
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on? All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Officejet K5400 Won't print black
If there are defects on the page, run a Level 3 clean from the control panel of the printer. Follow the steps below:
Press and hold the
Power
button.
Press the
Cancel
button one time and the
Resume
button nine times.
Release the
Power
button.
