20 Most Recent
Hitachi DZHS500A Camcorder Questions & Answers
DZHS500A will not turn on
Check for:
- Proper seating of the battery
- charged battery (try to run it off of AC power directly)
- bent battery contacts or corrosion of the contacts (you can clean them with a clean dry pencil eraser)
Hello, my Hitachi VM-H675LA is having some problems.
Please use the yellow pages website to find a camera shop that can help fix your camera. If that does not work, you can take it to your local Geeksquad/Bestbuy and they can work on the camera for you. Otherwise, you might also call Hitachi directly to ask them about the nearest repair shop that you could send the camera to.
Thank you.
I have an Hitachi with mini dvds. They play back
First find the format of the video.
Insert the video cd to the computer and right click the video file and the click the properties menu, watch the file type(i.e: .flv , .avi ,.wmv)
Basically the hitachi saves in mpeg2 or mpeg4 type.
Use the GOM player to play the video Or there are many more players available to play that video.
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection CableUse the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.Note:• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/chargerto power the DVD video camera/recorder.• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (externalvideo flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD ora disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, theCARD ACCESS indicator will light or blink red.If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may beprompted to restart the PC: In this case, follow the instruction and restart the PC.
