20 Most Recent Samsung NV10 Digital Camera Questions & Answers
Need manual for Samsung digital camera VLUU NV10
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04010900&prd_mdl_cd=&prd_mdl_name=NV10
2/25/2019 4:25:18 AM • Samsung NV10... • Answered on Feb 25, 2019
0answers
Camera charger flashes orange not charging the
I had first camera,2009 after few month my camera didn't want charged, it's always been flashing yeallow,. I gave it back to the shop i bought it from. They refund my money.
3/28/2015 8:06:21 AM • Samsung NV10... • Answered on Mar 28, 2015
My camera says card locked but I have no memory card in the camera. I can not take any pictures
The camera won't take photos without a card unless that model has a menu setting to allow that option (though nothing is stored). Put a different card in the camera and format it. If it doesn't see the card try formatted it first in the computer and then format it in the camera before you try shooting.
1/5/2015 2:27:48 PM • Samsung NV10... • Answered on Jan 05, 2015
Www samsungcamera com
those cards go bad I keep spares for my Nikon go to Walmart or someplace get another
8/19/2014 9:44:40 PM • Samsung NV10... • Answered on Aug 19, 2014
How to reset
Don't think toy fine a reset button on or in the camera. You only can "cold boot" the camera, by removing the battery and after a few moments reinsert it. If that does not solve the problem, you should contact a certifies cervce centre for your brand, or go to the dealer you bought the camera.
7/28/2014 1:15:10 PM • Samsung NV10... • Answered on Jul 28, 2014
4answers
Can I retrieve deleted files NV10?
you need rely on professional file recovery tool to get them back. A popular one is asoftech data recovery. This tool can deep scan the memory card and recover your lost files back without requiring extra skills. Here is the steps might be helpful to you:1. Connect camera memory card to computer. Under "My Computer", note the drive letter assigned to your memory card (usually G: or H:). If not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.2. Download asoftech data recovery program on your compute. here is the link: http://www.asoftech.com/adr/3. Install and start the program, select the drive where your lost files located, click 'Next'. Now the scanning process will start to search the deleted files. After a while you will then get a list of recoverable files. 5. Press Recover to perform full recovery.
7/18/2014 11:20:18 AM • Samsung NV10... • Answered on Jul 18, 2014
Deleted pictures on my samsung nv10
We should refer to an expert in this case. Although i am not so sure if the pictures can still be retrieved in digicam cases or if it is somehow similar to deleted file retrieval in PCs where there is still a possibility of "undeleting".
6/24/2014 9:13:04 AM • Samsung NV10... • Answered on Jun 24, 2014
I accidentally press the "delete" button so all my
no dear no way
5/12/2014 10:30:05 AM • Samsung NV10... • Answered on May 12, 2014
5answers
I accidentally deleted the photos on my camera. Is
I have had success with this... Download this photo recovery programhttp://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
5/12/2014 10:02:48 AM • Samsung NV10... • Answered on May 12, 2014
0answers
manual
I have a DV300 Samsung, can't down load onto my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/20/2013 8:35:58 PM • Samsung NV10... • Answered on Aug 20, 2013
PC will not recognize camera
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/8/2013 3:29:15 PM • Samsung NV10... • Answered on Aug 08, 2013
0answers
Have installed my camera software into my pc,
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
2/26/2013 4:50:32 AM • Samsung NV10... • Answered on Feb 26, 2013
I want to transfer my camera images to a memory
Use the "Copy to Card" command in the setup menu. See page 52 ofthis manual.
2/26/2013 4:49:36 AM • Samsung NV10... • Answered on Feb 26, 2013
The lens is difficult to
2/26/2013 4:49:24 AM • Samsung NV10... • Answered on Feb 26, 2013
Does this camera have a timer and how do you set
Select "TIMER" from the menu. See page 29 of this manual.
2/26/2013 4:49:14 AM • Samsung NV10... • Answered on Feb 26, 2013
Samsung NV10 Digital Camera Logo
147 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
pc will not recognize camera
  • Cameras
