20 Most Recent
Toshiba 19HLV87 19 in. LCD HDTV Questions & Answers
Nofuncionael controlremoto
From what I can see from what information you have left, the remote does not work.
Try a universal remote
How to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
Toshiba 19hlv87 blinking
It is going on protection mode. Change the power outlet to some other that works. Try changing the input device to something that works. If it does not work, try switching off the TV manually, remove the plug after switching off the power outlet, wait for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
Take off stand 19
The owner manual should have this but a word of CAUTION: most sets require the set to be laid face down and up to 6 bolts removed---It is extremely important the screen not be forced on a hard surface when doing this as it can instantly be damaged/destroyed----if that is damaged it is fatal.
Toshiba 19hlv87 turns off in 3 seconds
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.
How to connect my ps3
You would have to use the HDMI input with the PS3 to your TV, or if composite cables are available with the PS3, you can hook them to the composite inputs on the back.
