20 Most Recent Samsung CLP-300N Laser Printer Questions & Answers
0answers
0answers
Red light stays on and printer wont work
Check the waste toner bottle on the left side. If that is full, you will get red light. Just empty it if is full of waste toner. Re-use the waste toner bottle.
4/4/2011 1:48:28 AM • Samsung CLP-300N... • Answered on Apr 04, 2011
New black toner installed black print is very
Sounds like the developer blades for the black toner is dirty. This can be fixed two ways:
The first way is the easiest, but most expensive is to buy a replacement imaging unit for $100+. (This is probally more than the original cost of the printer, and does not prevent it from happening again)
The second way is to take your existing imaging unit and open it to clean the blades that are dirty. It will take about 30 minutes, but you will learn a useful maintenance skill if you want to keep this printer. I have posted instructions in my Tips section. See this link, Sounds like the developer blades for the black toner is clogged. This can be fixed two ways:
The second way is to take your existing imaging unit and open it to clean the blades that are clogged. It will take about 30 minutes, but you will learn a useful maintenance skill if you want to keep this printer. I have posted instructions in my Tips section http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
3/8/2011 9:47:21 PM • Samsung CLP-300N... • Answered on Mar 08, 2011
Hello !! I have a problem
If the only thing it does is click and the motors or LED don't come on, means that the power supply board has failed. I had it happen to me and the problem turned out to be a bad capacitor. The power supply is located behind the right panel. If you are familiar with electronics, check the capacitor and see if it is blown. If it is, replace it and it should get you going again. Hope this helps you.
3/7/2011 8:55:10 PM • Samsung CLP-300N... • Answered on Mar 07, 2011
2answers
My roller heat have damage i want change it
Heres a website with everything you will need: http://www.nextag.com/clp_-_300-toner/stores-html
3/4/2011 1:48:20 PM • Samsung CLP-300N... • Answered on Mar 04, 2011
0answers
Always paperjam, the printer takes the paper 10cm
you should clean the roller of the printer with wet cloth, els consult with a qualified technician for technically handle.
good luck
11/27/2010 7:35:36 AM • Samsung CLP-300N... • Answered on Nov 27, 2010
I turn on the printer,
I have had this problem and I cleaned the waste container, which is located on the left on the 4 cartridges. It collects excess dry ink and covers the led which an indication that is is full.
Just shake all the contents of it, outside the house as it is black soot that you do want on your clothes or carpet and try again.
I had to do this a few time to clear it all.
10/1/2010 10:30:19 AM • Samsung CLP-300N... • Answered on Oct 01, 2010
Samsung CLP-300N Printing Blank Pages
laser scanner unit faulty.
9/20/2010 11:33:00 PM • Samsung CLP-300N... • Answered on Sep 20, 2010
Paper feed works only with
I think you just needed a little more tension on the roller that pulled the paper in.
Remove the rear access door (see manual). Off to the left near the feeder roller you will see a spring. move the spring to the END of the plastic arm that it is attached to (if it is missing you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch, and that is all all. Your printer should now feed a single sheet of paper with no issues.
Take care.
9/12/2010 9:46:11 PM • Samsung CLP-300N... • Answered on Sep 12, 2010
We have white lines running through the print
http://www.printertechs.com/tech/print-defects/print-defects-index.php
this link will explain
3/31/2010 9:43:59 PM • Samsung CLP-300N... • Answered on Mar 31, 2010
Paper not being picked up - printer is about a year old
try to clean the pickup rubber (roller) whit dishwasing soap
3/11/2010 2:53:36 PM • Samsung CLP-300N... • Answered on Mar 11, 2010
2answers
I updated the firmware on my CLP-300N before
What problem acutally you are facing ?
3/11/2010 9:20:23 AM • Samsung CLP-300N... • Answered on Mar 11, 2010
Colour or black/white the black alwaws prints
The second way is to take your existing imaging unit and open it to clean the blades that are clogged. It will take about 30 minutes, but you will learn a useful maintenance skill if you want to keep this printer. I have posted instructions in my Tips section.
2/20/2010 4:04:39 AM • Samsung CLP-300N... • Answered on Feb 20, 2010
How do you clean samsung clp 300n printer when
youl find the answer here, any problems get back in touch and please rate me.
http://www.retrevo.com/support/Samsung-CLP-300-Printers-manual/id/691ag124/t/2/
2/12/2010 5:44:31 PM • Samsung CLP-300N... • Answered on Feb 12, 2010
Samsung CLP-300N Laser Printer Logo
Popular Tags
59 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
CLP Samsung
  • CLP Samsung
Most Popular Question
roller heat damage want change
  • Office Equipment & Supplies
