20 Most Recent Sony Cyber-shot DSC-W90 Digital Camera Questions & Answers
0answers
4answers
Sony cybershot 8.1 - Retrieve deleted photos
yes, you can recover deleted photos from Sony Cybershot digital camera with photo recovery software, recommended asoftech photo recovery which helped me before. you may refer to this step by step guidehow to recover photos from digital camerathe guide is easy to follow and works well for me. hope that it can help you too!
11/19/2013 1:16:39 AM • Sony Cyber-shot ... • Answered on Nov 19, 2013
Hasil gambar foto terpotong - potong. Bagaimana solusinya?
potong foto
12/4/2012 2:58:16 AM • Sony Cyber-shot ... • Answered on Dec 04, 2012
The screen is completely black when viewing to take pictures, if you take a picture the only thin that appears is the same black screen as before taking it?
Many older cameras began to have dried up electrolytic capacitor. It can be cured by having power on for a while to have moisture restore the capacitor function which is to power the camera on needed current surges. If you don't use it often, you lose it.
2/9/2012 6:02:19 PM • Sony Cyber-shot ... • Answered on Feb 09, 2012
2answers
How to reset sony dsc-w90 to factory setting
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.Follow the appropriate procedure below for your camera. Using an Initialize option in the menu Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.Using a RESET button: Locate the RESET button on the camera. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. After 2-3 seconds has elapsed, release the RESET button.Performing a manual power reset: Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera.If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.Hope this helps.
10/8/2011 7:12:17 AM • Sony Cyber-shot ... • Answered on Oct 08, 2011
Sony cybershot audio buzzing
I have the same problem, and cant seem to fix it. I know it has to do with the audio chatching the camera making the noise. Listen, take your camera and turn the function to take a video clip, then listen to your camera. Isnt it making the same noise as you hear on the video clip?
9/10/2011 9:10:28 AM • Sony Cyber-shot ... • Answered on Sep 10, 2011
Turn the power off and one again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
6/8/2011 2:58:34 AM • Sony Cyber-shot ... • Answered on Jun 08, 2011
My pictures have green tone to them
hello. your camera needs to be reset to the factory settings. go through the menu until you find reset and then click on it.
5/23/2011 12:35:51 AM • Sony Cyber-shot ... • Answered on May 23, 2011
When i turn on my camera it tells me to turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/3/2011 2:49:51 PM • Sony Cyber-shot ... • Answered on Mar 03, 2011
My sony says that my
If u are using a mini sd card then on the card itself there will be a lock. make sure that the lock is down.
2/21/2011 5:32:40 PM • Sony Cyber-shot ... • Answered on Feb 21, 2011
Sony Cyber-shot  DSC-W90 Digital Camera Logo
91 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
sony cybershot 8 1 retrieve deleted
  • Cameras
