20 Most Recent
Nikon D40 Body Only Digital Camera Questions & Answers
Fitting a Sigma Lenset to Nikon D40
You have to make sure you bought the sigma lens with a NIKON mount. Sigma makes a Sigma mount as well as a Canon mount, of course neither of those mounts will work with your camera. Also you must also make sure your lens is the Sigma 70-300 HSM (/Hyper Sonic Motor) or it will not AF on the D40. I just bought this lens from Abes of Maine and I love it on my D40.
Taking pics
That's because the Nikon D40 does not have Live View. Up until a couple of years ago, no DSLR's had live preview, due to the design of a DSLR over a point and shoot, as it has a pentamirror arrangement that effectivly deflects the light path to the viewfinder and only to the sensor when the internal mirror is raised. Early live preview models from Olympus had the world's first Live View system by flipping the mirror so that the picture preview could be seen on the rear monitor. Most manufacturers now incorporate Live View into most of their models but most Nikon consumer models do not as yet, apart from the newly relesed D90. The D40 and D40x are two year old designs and therefore do not have the more "modern" specs of say the Olympus E520 or Canon EOS450D. Most photographers trading up from a compact to a DSLR are surprised when they cannot use the LCD monitor in the same way. However for most aspects of DSLR photography Live View is not something that is used all the time, low down shots, and macro perhaps being the most convenient use, but for general photography there is no substitute for framing through the viewfinder, that's what we've been used to doing for over half a century! Besides as pointed out previously a DSLR is often too heavy to hand hold at arms length especially with a long lens.
I dropped my polaroid i533 camera and it wont turn on?
Sounds like it might have a messed up the lens. You have some options. Get a one off ebay that has a damaged LCD if your going to repair it yourself. or you can have it repaired it should not cost to much to fix. On those unit it takes about 30 min to change out the lens and test it out. some times less if you are going to try to repair it your self please watch for the flash compasitor. It has a bit of a bite if you touch it.
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Nikon Teleconverter
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600.
Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
My Nikon D3200 says shutter error can I fix this issue myself?
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
