20 Most Recent
Kingston Kpex100 Digital Media Player Questions & Answers
Cant play the download videos
This Kingston model siu[ports the following video formats.
Video: MPX format, requires transcoder software to play WMV, ASF,MPEG 1 & 2 and AVI formats
If your player cannot play a video then it is an incompatiblevideo file format, then you need to convert that video file to a format thatyour MP3 player uses.
Click on this link for instructions on converting videofiles for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Audio only plays from left headphone
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
IT WoN't TuRN oN!!!!!
.,I think i could help you with that.. It happened to my KPEX100 last week.. Here's what you should do..
Remove the silicon Case (if you have put it on),, look into both sides of your mp4 and try to see the small hole in there.. it says "RESET".. don't worry, your files will not be erased.. Get a Pin or anything that fits inside the small hole.. then try to press the pin inside the hole.. you will feel like hitting a small button there.. it will reset your KPEX.. try charging it on your computer or an outlet (if you have a charger for that) or try to connect the USB slot as if transfering files.. As soon as the KPEX started to light up,, its fine then.. =)
I need mpx vedio converter
You may try this total video converter, I always use it to convert video
including AVI, MPX, WMV, MP4, MKV, MPEG, MOV, VOB, 3GP, FLV, etc. my friends
recommend it to me, it's safe and works pretty well. The conversion quality is
good, and the conversion speed is really fast. Here is the download link.
http://video-converter.reviewstown.com/video-converter-wondershare.html
K-PEX 100 2GB not recognized by computer
try reinstalling the driver from the other solution or got to kinstons website and update the firmaware
try installing windoes xp service pack 3 if not allreadyinstalled
Displaying "cnt NAND format"
i think that may be a problem with NAND memory chip, witch is your mp3 2GB memory chip, it may be because of shocks or something like thate. A reheating of this chip may solve your problem, easiest way to do it is to go on a mobile service and ask them to do it for you
Help charge problem.......................................
it'll be a little expensive, but after about two years of missing my cable, i finally found one that works! it won't let you upload content to it, but it will charge. the solution is a little expensive, though. When you buy the PS3 game, Warhawk, it comes with a little bluetooth headset and a usb cable to charge it. This cable fits the KPEX! It's the best solution i could find. I guess i'll just have to buy a miniSD card to use new content. Hope this helps!
