20 Most Recent
Sony BRAVIA KDL-40S2400 40 in. LCD HDTV Questions & Answers
Bought in 06/2007 a Sony
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Only 1 hdmi outlet on
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
Necesito el firmware de LCD SONY KDL-40S2400 se los agradezco
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2300 posts now. All are related to
electronic equipment repair help.
Search the site by 'Timeslide' option.
It will make search easy. Or,
type in the brand name to your device into its search box, and press "Enter"
Sony bravia start up boing noise is irritating help
If the model is not listed correctly let me know with the make a comment button on this page---KDL-40S2400 IS A LCD SET---usually on that model on turn on you may hear a high pitched buzz which is a issue with something on the power board making a sound---If model is a KV type it is another issue.?
Can't get the Bravia top and bottom panels to stay
Good day!
That problem is called close caption..
please go to the menu using your remote then go to the settings and find close caption text..
after you find the close caption please turn it off after go back to the TV mode then see if the problem is still there..
If the problem is still there just add a comment to give you another solution..]
NOTE: this solution is based on my actual experience before on my TV...
thank you and good luck.
No image,but audio
Tv turn on now,have picture flashes only a few sec. than dies than sound left only?Yes,than those 2 long board call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
How do you replace backlight
The backlighting is composed of 2 elements : the inverter boards that take the low voltage from the power source and transform it in the high tension , and the CCFL tubes that convert that tension into light. The tubes extremely rarely fail, so you must refer to the inverter boards.
To replace then you do just like for every other board: you take the back cover off, you locate the board, unhook all the wires and connectors, unscrew the supports and take it out. The fitting is the opposite.
Unfortunately Sony refuses to allow other companies or sites to sell new replacement parts for its products so either you look for it on sites like Ebay for second-hand/used ones or you order anew one directly to them
https://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
It will cost you around $400, shipping included
There appears to be a large black smear that is
this appears to be an LCD if the model is right. If so then i hope u have extended warranty because what you have is a bad screen. something has caused the layers to separate, either a cleaning solution you used of just a plain unlucky. but to get rid of it replace the LCD Panel which is not cheap. Good luck. PS dont use any kind of cleaning solution it ruins the screens
Broken lcd screen
Call Sony at 1-800-282-2848 0r 1-201-986-3246 or 201-986-3335 they can give you a price. Dovecat
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
