The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
If the issue persists, perform
a power resetting of the Camcorder. To perform power resetting, please remove
the battery pack, turn the Power switch to ON for more than 15 seconds, turn
the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
71 questions posted
310 Questions
243 Questions
242 Questions
159 Questions
150 Questions
