20 Most Recent
Casio EXILIM EX-Z1000 Digital Camera Questions & Answers
Flash not working
Sounds like a burn out, or a bad lamp. The flash is subjected to a huge jolt of electricity each time it fires, and breaks easily, especially when hot. If you are taking many flash photos, you should stop after 15 or so, to let the flash unit cool.
Good luck with Casio, if you are still under warranty. It will probably mean mailing them the camera for fixing, or replacing. Sometimes you can take it back to where you bought it for repair.
How do I turn the flash off?
- Press 'down' key (which is located below SET button) once.
- Use 'left' or 'right' key to select mode with crossed flash symbol in a circle ('flash off' mode).
- Press SET button to submit selected mode
- Make photos
Is it allows to use 32 gigabites memory card?
I'm surprised the 32GB card is working at all. The Z1000 works with MMC and SD cards, which max out at 2GB. If the 32GB SDHC card is working at all, the camera will treat it as a 2GB SD card, unable to see the rest of the memory.
PC using XP OS does
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
All of a sudden my Mac does not see my casio
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
The card is locked so the camera doesn't work. how do I unlock it?
If your camera uses a SD memory card then -SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
I can not transfer my photos to my computer tells me problem with i/o
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Opens then closes
I suggest you try a new battery, most camera batteries are good for 1 to 3 years.
