20 Most Recent Kodak EasyShare C875 Digital Camera Questions & Answers
SD Memory Card Pictures Missing
First make sure that the photos are not actually on the camera's internal memory and not shot on the card to start with. Do this by trying to look at the photos through the camera with the card out of the card slot. Next before taking anymore pictures try putting the card into a different computer and card reader. If it still shows up empty you can try several recovery softwares online for free, only paying for them after they have found your photos and are ready for saving. If that doesn't work if you have a local photo store still they will offer recovery service and recovery services are available from companies like DriveSavers.com. Be warned, it can be expensive.
11/20/2017 6:06:43 PM • Kodak EasyShare... • Answered on Nov 20, 2017
I have a Kodak EasyShare
Try a hard reset of camera electronics to factory defaults. If that does not do it, them maybe it is time to go shopping since repair is not cost effective.
9/12/2017 8:58:10 PM • Kodak EasyShare... • Answered on Sep 12, 2017
2answers
Lost all pictures taken today. all pictuers taken
Watch this video and try to use it recover your photo. It's very easy to use. Hope you like it.
1/5/2017 9:14:01 AM • Kodak EasyShare... • Answered on Jan 05, 2017
Mac os x 10.6.8
HI, I cannot download Ezcast in my macbook 10.6.8, any help please !
3/7/2015 2:26:00 AM • Kodak EasyShare... • Answered on Mar 07, 2015
My batteries seem to need replaced quite often. Should I use a special brand
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera. Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera. Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended. Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power.
1/4/2015 1:44:49 PM • Kodak EasyShare... • Answered on Jan 04, 2015
After one or two uses a AA battery no longer powers the camera
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera. Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera. Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended. Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
1/4/2015 1:44:16 PM • Kodak EasyShare... • Answered on Jan 04, 2015
My Kodak C875 digital camera says internal memory full how can I fix it
Do you have the optional sd memory card instaleld in the camera? Have you formated the sd memory card or MMC card as suggested on page 37 of the user manual. on page 36 on image storage settings = If set on Auto it uses the external card if there is one installed rather than the internal memory. You need to have a memory card installed in the camera ! see page 5 of the user manual. http://resources.kodak.com/support/pdf/en/manuals/urg00594/C875_GLB_en.pdf
1/4/2015 10:04:58 AM • Kodak EasyShare... • Answered on Jan 04, 2015
How do i transfer pictures from my camera to my computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/21/2014 4:06:08 PM • Kodak EasyShare... • Answered on Nov 21, 2014
0answers
No Flash
Read instructions, there are alot of options with devices, make sure to read directions thouraghly. If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
4/13/2014 4:33:38 AM • Kodak EasyShare... • Answered on Apr 13, 2014
13answers
Camera error # e45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken.
Also i have heard some people bashing the camera a couple of times to get it working..
hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can, one I did have to get a little more medieval on and bashed aginst a bit of carpet on the bench.. but it worked... might be worth a go if the next step is the bin...
3/28/2013 3:51:40 PM • Kodak EasyShare... • Answered on Mar 28, 2013
Kodak EasyShare C875 Digital Camera Logo
275 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
sandisk sdhc card
  • Cameras
