20 Most Recent
Sony Handycam DCR-SR80 HD Camcorder Questions & Answers
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
- Make sure the battery is firmly attached and the AC adapter is securely connected.
- If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
- Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
- If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
- Make sure the metal contacts on the battery are free of corrosion.
Recording device disabled
I'm sorry that the Camcorder is displaying the error message. Please follow the troubleshooting steps provided below and check the operation:1. Please insert a different disc and close the disc tray firmly. 2. Perform Reset by following steps: 1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button. 3. Perform a manual power reset by following the steps: 1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.If the issue persists after following all the steps service will be required. You can find repair information and initiate service at: http://eservice.sony.comThank you for your time.
My Sony Handycam SR-80 not
It is due to the dead battery. Replacing the battery will be fine.
You can get your battery at
www.batterybay.net I think. If you don't know which battery is for your device, you can send them an email with the part number of your original battery and they will get back to you so quickly. Hope this information would help you!!
How to use a sony handycam dcr-sr80 hd as a web
It is not possible to use the Camcorder as webcam using USB interface as the Camcorder does not have the USB Streaming feature.
You may connect the Camcorder to the A/V input of the Computer to use it as webcam.. However, it is required to use a software which is compatible for capturing videos from A/V interface to use it as webcam.
Error code
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
I selected the HDD Format button on error is there
To my knowledge no camera hard-drive can be got back that was formated, BUT, yes BUT you can connect the camera as normal to a PC, then go into My Computer from the windows start button, then as well as seeing your PC disks, one will say somthing like camera, highlight that with mouse, right mouse click, and hit restore menu and wait, hope it does it, I have seen this work like magic.
Good luck.
David UK
Please help me I am very slow understnding. My
The disk within the camera is called a Hard-Drive, to burn the movie on DVD you connect the camera to PC with a Firewire cable, and go into Windows Acc file, there you will see Making movies software, just let windows do it by pushing buttons as prompted.
