20 Most Recent
Samsung YPT9 Digital Media Player Questions & Answers
Which video format i can play on my samsung ypt9b
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Which format can i play on my samsung ypt9b
Hi rashidthahee...The music format for you player is MP3 and WMA music files, they are compatible with your player.
MP1 or MP2 files
which only have a changed extension to MP3 may not play on the player.Please take time to rate meFor a "Free Format converter" go to the following webpage
http://formatoz.com/Bud
Windows XP does not see yp-t9 as a device when
Connect it with the USB cable and if that dosen't work install the software that came with it. If your memory card for the device is removable use an adapter to connect the card to the PC.
How do you delete song?
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
I reset my samsung yp-t9 to get all my songs off
you need your firmware be upgraded
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=YP-T9JQB/XAA#
download zip version and put the rom file into yp
Video file type
Audio Capabilities format: MP3 • WMA • ASF
Video Capabilities format: MPEG4 / WMV
P.S.
Daniusoft video converter: help u convert all mainstream videos even HD video, home video, youtube video to Samsung YPT9 Digital Media Player easily
I need help deleting recorded files or songs from Samsung YP-T10
plug it into your usb port on the computer.
go to 'start' 'my computer' click on the new drive it shows, which will be the mp3
open the mp3 player files, click on video , files, music, or whaterver it is you want to delete. The files will show........click on the one you want to delete and hit 'delete' on your keyboard......done.
I need help
donload a firmware upgrade toolits in the samsung downloads pge
Ypt9 2gb problem
take out the pilot transferer and do not touch it for a few days and see what happens i have a 8 out of 10 results thank you for reading this goodbye
danigirlb55
Can't connect to my pc
Mine had the same problem and here's how I fixed it :
First, connect your YP T9 to your PC
Once connected, on your PC go to :
-Start
-Control Panel
-System
-Hardware
-Device Manager
Then you'll se your YP T9 appear under either "portable devices" or Universal USB or USB something...And since it's not working properly, you should see a yellow exclamation point besides it.
Then click on the YP T9 with the exclamation point and right click again on it, then press "update driver"...Then follow Window's instruction to update it, it's quite easy...
That should do it! : )
