20 Most Recent Panasonic Palmcorder SDR-H18 Camcorder Questions & Answers
2answers
Panasonic SDR-H18 Camcorder - I would like to
Did you ever figure out how to do this? I have misplaced the cord to transfer files from the HD to the computer, and I would like to not have to purchase one through Panasonic (Best Buy didn't have one). I just want to transfer the files from the HD to the SD card while in the camera, and then take the card out and put it in the Mac. Any luck?
8/14/2021 10:41:46 PM • Panasonic... • Answered on Aug 14, 2021
I need image mixer 3 software for a panasonic SDR H18
hi, software for similar applications are available in many web sites, use search engine.
2/19/2016 1:30:08 PM • Panasonic... • Answered on Feb 19, 2016
Lost the imagemaker disc. Have new computer. How can I get this software so I can download my movies?
it's available at the Panasonic website.
2/5/2016 5:46:18 PM • Panasonic... • Answered on Feb 05, 2016
2answers
I want to download the video but do not have software; is there a free download available for a windows 13 pc?
Hi, Windows 13? The newest version of Windows in 8.1 32/64. Windows 10 will release in August this year. So say they. Windows 13 probably will appear in 20... Isn't it ? * I don't undestand what you need ! What kind of video. Need U prog too run movies,videos,etc.? Or U have drivers to connect your device to pc? If u need prog for playing videos, I will suggest you GOM Player (Be carefully WHEN YOU INSTALL IT !,because are 2 mone prog in under check box ! Have a nive day
6/24/2015 1:05:26 PM • Panasonic... • Answered on Jun 24, 2015
My sdr-h18 will not turn on even after i charged
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
12/17/2010 4:30:08 AM • Panasonic... • Answered on Dec 17, 2010
I have lost my panasonic
I have lost the dvd disc for the panasonic SDR-H18 camcorder,can i download software anywhere on thepanasonic uk site?
11/17/2010 5:21:09 PM • Panasonic... • Answered on Nov 17, 2010
I put my video clips on an expasion drive. They
AVCHD Converter for Mac brings you the easiest way to convert.MTS or .M2TS video files to Mac compatible formats, like MOV, MP4, M4V, MPEG, DV, 3GP for playback on QuickTime.
8/18/2010 11:37:56 AM • Panasonic... • Answered on Aug 18, 2010
My Panasonic SDR-H18 will not power up, even when
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
8/17/2010 3:11:08 AM • Panasonic... • Answered on Aug 17, 2010
I have lost both cds that came with my canon fs100 camcorder
Do you have windows XP? If so I don't think you need the cd. It's **** anyway. I may can help.
2/15/2010 4:18:36 PM • Panasonic... • Answered on Feb 15, 2010
Panasonic SDR-H18 Camcorder I get no audio
I found, from the Best Buy Geek Squad, that all Hard Drive Video cams use a audio format that only works with their hardware. If you burn a DVD (using their software) is audio will be present.
1/13/2010 5:34:42 PM • Panasonic... • Answered on Jan 13, 2010
Software
where can i get free software for my panasonic sdr-h60 camcorder?
8/27/2009 5:02:45 AM • Panasonic... • Answered on Aug 27, 2009
The photos are very dark. When I take interior
this camera has a menu to adjust the settings for light and dark. Go to settings and you should be able to fix it.
enjoy
7/17/2009 4:43:45 PM • Panasonic... • Answered on Jul 17, 2009
3answers
Panasonic SDR-H18
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
5/25/2009 11:06:43 PM • Panasonic... • Answered on May 25, 2009
2answers
Saving movies to computer
when you install you software you have to set the same VIDEO SYSTEM that your camera. Select NTSC.
aldof
4/26/2009 5:35:33 PM • Panasonic... • Answered on Apr 26, 2009
Der Videotyp is not PAL - code 442-E-100
install the software in ntsc mode...it was my solution
User "aldof" said it in other post...
Thanks to him
4/26/2009 5:35:16 PM • Panasonic... • Answered on Apr 26, 2009
I am unable to connect it to my PC for transfereing pictures.
I don't know if the usb cord is a good power source for it. That wire may provide data service only but no power to the camcorder.
1/7/2009 9:57:16 PM • Panasonic... • Answered on Jan 07, 2009
How to connect SDR-H18 to IEEE-1934 port
I had a look and it looks like a regular mini usb cable that you need to connect to your laptop, or a regular mini firewire cable, both are available online for under $10 or at a local electronics store
12/30/2008 2:11:41 AM • Panasonic... • Answered on Dec 30, 2008
Trying to save video from camcorder to dvd disk
This site has a lot of very useful tips to convert your files to a format you can burn to dvd
http://convert-mod-files.allofyourquestionsanswered.com/convert-mod-files-with-ffmpegx-mac/
If you got discs with the camera look for a program on there called Cyberlink Power director it will convert the files for you heres a link that will give you full instructions as well as a link to Other programs that will do the job
http://i.nconspicuo.us/2007/01/26/convert-mod-files-to-mpg-or-avi-jvc-everio-hdd-camcorder/
Hope that helps
Please rate my solution if it does help
8/22/2008 2:57:54 PM • Panasonic... • Answered on Aug 22, 2008
2answers
Where is it ?
You don't say how you edited your video and created the DVD. Assuming you using Imagemixer 3 that comes with Panasonics, there is a *.i3e (project) file somewhere. By default on my Windows XP system, it is at C:\\Documents and Settings\Owner\My Documents\ImageMixer3\VideoEditorxx.
Bernie
8/7/2008 12:06:49 AM • Panasonic... • Answered on Aug 07, 2008
Panasonic Palmcorder  SDR-H18 Camcorder Logo
44 questions posted
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Palmcorder Panasonic
  • Palmcorder Panasonic
Most Popular Question
lost panasonic
  • Video Cameras
