20 Most Recent
Samsung HL-S6187W 61 in. HDTV Questions & Answers
Why does my samsung 61" DLP Standby/Temp and Lamp light flashes 29
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
9/7/2014 5:18:47 AM •
Samsung...
Answered
on Sep 07, 2014
TV TURNS ON AND TURNS OFF
There is a thing called a capacitor in the power supply area. U're having problems with that.. take it to a techie......
1/13/2014 5:43:49 AM •
Samsung...
Answered
on Jan 13, 2014
The television is randomly turning itself off
My initial concern would be the unit getting adequate air flow to prevent over heating. If the set is in an enclosure or even pushed against a wall this could be an issue. Also be sure the air intake for the fan is not blocked with dust which can build up over time. If the unit is turning off after running for a time I would look into this. Also the set likely has a temp indicator which would come on if the operating temperature is getting too high.
9/12/2012 3:08:31 AM •
Samsung...
Answered
on Sep 12, 2012
