20 Most Recent
Nokia E61 Smartphone Questions & Answers
Nokia E61 Wifi connection
setup Internet access point for WLAN
menu>tool>settings>connections>access points
select options>new access points
Enter Connection name
Data bearer: select Wireless LAN
WLAN network name: select search wlan to select wlan in range.
network status: select "public" if you can see wlan in range
WLAN network mode: select infrs or adhoc
WLAN security mode: select same settings used by WLAN access point
WLAN security settings:
Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
10/28/2013 9:23:38 PM •
Nokia E61...
Answered
on Oct 28, 2013
Hi I need to unlock my Nokia E61-1. My IMEI: 356211002140864 please!
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
9/15/2012 6:43:14 AM •
Nokia E61...
Answered
on Sep 15, 2012
Solution to unlock Nokia E61i
your IMEI: 351880010069367
mastercode:
142066711x
The mastercode can be entered instead of standard security code.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
8/23/2012 5:29:37 AM •
Nokia E61...
Answered
on Aug 23, 2012
Phone lock
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
8/5/2012 3:00:19 AM •
Nokia E61...
Answered
on Aug 05, 2012
Just hard resset phone by pressing *, 3, green
Man, i've done this too on my 5310 xpressmusic, and now, when I try to power it up, is asking me for pin code, then show the Nokia 2 hands picture, and then the light is on and off, and then the phone turn off. Can any1 help me ?
3/22/2012 2:33:18 PM •
Nokia E61...
Answered
on Mar 22, 2012
I wanted to put a
First, check the original phone documentation, sometimes the PUK code is supplied with the SIM paperwork.
If not, then you can only obtain your PUK from the network provider. They will only supply it to the registered subscriber, so if your SIM is a pre-pay credit version and you have never registered it then you cannot get a PUK.
7/23/2011 5:00:22 PM •
Nokia E61...
Answered
on Jul 23, 2011
My nokia e61 goes off
That is the problem of battery. Your battery should be used for a long time and so the capacity is dropped alot. You can buy an original battery for Nokia E61 in the market or on ebay. If you look for a cheaper replacemebt battery, you can go to
www.batterybay.net. They can provide 1 year warranty for any battery bought from there and they offer free shipping.
One more tips that don't try to buy replacement battery on ebay as those cheap batteries used the worst class of cells into the battery. It may cause danger and unstable performance for your phone.
7/4/2011 12:01:27 PM •
Nokia E61...
Answered
on Jul 04, 2011
Sending and Replying messages
You should download the patch from the Nokia Europe website for SMS for the E61. This is recommended for all users, as it will significantly increase the speed of sending messages. Vir
2/4/2011 7:12:52 PM •
Nokia E61...
Answered
on Feb 04, 2011
Cannot send sms on nokia e61 - new sudden problem, no reason
Full working!!!!
I solved SMS sending problem with E61
Just hard resset your NOKIA phone by pressing in same time this four buttons:
1) * (star) button
2) 3 button
3) green tab (call acceptance ) button
4) power on - button
NOTE Press all this in same time and wait until phone load.
2/4/2011 7:00:54 PM •
Nokia E61...
Answered
on Feb 04, 2011
