20 Most Recent
Advantech 700 Series Intel Pentium /Celeron Processor-based ATX Motherboard, RoHS Version (AIMB-7... (AIMB760G200A1E) Questions & Answers
Cant boot with my cd no perating system
try the following:
BIOS is set to allow for boot from cd
The CD is not corrupted and that the OS is suitable for your hardware
Can you boot from floppy?
Check CD data cable and jumpers are set correctly.
Good luck,
Rob
How to connect power led & reset ledin mother
firstly u find 9pin jack on motherboard its near about pci slot and their is print power switch,power led and reset switch. some wires are comnig from your cabinet their is print po sw,reset,hdd,pwd led
Ppc 153t
if it is damaged, then it will need to be replaced. You will have to determine whether or not it is an IDE or a SATA cable; although if you REALLY have it connected to a CD-ROM, then it is an IDE cable.
If you have local PC repair shops in your city, give them a call. They will have perfectly good 'used' ones they likely will be glad to give away....I know I do ! lol
If you do not, then you can get them online cheap here :
StarTech Model IDE66 18 Ultra ATA 66 100 133 80 wire IDE Cable StarTech...
11/13/2014 8:33:52 AM •
Advantech...
Answered
on Nov 13, 2014
Ribbon to hard are bad
Hi
Do you need the 40 wire connector ribbon cables or do you need SATA ribbon cables to connect the hard drive to the motherboard?
3/21/2009 9:21:38 PM •
Advantech...
Answered
on Mar 21, 2009
Mother board driver
You can try Nodevice.com
or type free download motherboard drivers in google search
9/28/2008 4:39:05 PM •
Advantech...
Answered
on Sep 28, 2008
