20 Most Recent Samsung UN46EH5300 - 46" LED-backlit LCD TV - - UN46EH5300FXZA Questions & Answers
I have a Samsung UN46EH5300FXZA (Version UF03) 46" LCD TV with odd issue
What's the issue?
1/15/2021 9:08:44 PM • Samsung... • Answered on Jan 15, 2021
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
4/4/2016 10:52:18 PM • Samsung... • Answered on Apr 04, 2016
I WANT PASSWORD TV SHOWNIC TYPE LD-F42HS90 PLASE
2590,220184839
8/17/2016 2:53:29 AM • Samsung LE... • Answered on Aug 17, 2016
0answers
Le32b530
Be the first to answer 8/29/2015 10:47:23 PM • Samsung LE... • Posted on Aug 29, 2015Be the first to answer
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3/11/2015 1:46:13 PM • Samsung LE... • Answered on Mar 11, 2015
Television keeps clicking like it wants to turn on but doesn't come on. will come on ocassionally after a long wait
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
3/4/2015 7:33:18 AM • Samsung LE... • Answered on Mar 04, 2015
My tv has sound but the picture is white. Unable ti see the screen. Can see shadows. What is wrong with it? It's a samsung lcd
i need the model,but the problem is in the T-con board.
1/27/2015 5:34:52 PM • Samsung LE... • Answered on Jan 27, 2015
0answers
0answers
How to repair
Be the first to answer 8/17/2014 8:46:26 PM • Samsung LE... • Posted on Aug 17, 2014Be the first to answer
Samsung 46 inch keeps turning on and off immediately by itself
Most likely the power supply capacitors. you can identify them by their bulging tops.
7/24/2014 6:56:12 PM • Samsung LE... • Answered on Jul 24, 2014
0answers
0answers
0answers
0answers
LE40A676 t-con
Be the first to answer 5/23/2014 9:17:40 PM • Samsung LE... • Posted on May 23, 2014Be the first to answer
Samsung UN46EH5300 - 46" LED-backlit LCD TV - - UN46EH5300FXZA Logo
2 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
picture dimmed see picture in menu
  • Televison & Video
