20 Most Recent
Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator Questions & Answers
My fridge blows warm air
There is an air filter that is located below or behind your appliance. To cool, the refrigeration unit must have circulating air coming into the machine. Look for a honey-comb like panel, similar to a car radiator and clean it. This should radically cool down the operation of your fridge/freezer. Lint and dust collect in the radiator area and block airflow.
I just bought a new house and it has an Amana
one thing to check is the condenser fan on the back by the compressor. Is the freezer cold enough? if so check the evaporator fan and defrost is working properly. Look for frost covering the back of the freezer if it is there it is a defrost problem
Temperature frigeration air flow very weak
Won't cold enough or poor cooling is often the result of a heavy frost
build-up on the evaporator coils or a condenser that is clogged with
dust, lint, and dirt. Firts check this components...
Evaporator coils
Poor cooling is often the result of a heavy frost
build-up on the evaporator coils. You can't see these coils without
removing a panel on the inside of your freezer. A sure sign that there
is a build-up is the presence of any frost or ice build-up on the inside
walls, floor, or ceiling of the freezer. Such a frost build-up usually
indicates a problem in the self-defrosting system or damaged door
gaskets.
The refrigerator is supposed to self-defrost
approximately four times in every 24 hour period. If one of the
components in the self-defrosting system fails, the refrigerator
continues to try to cool. Eventually, though, so much frost builds up on
the evaporator coils that the circulating fan can't draw air over the
coils. There may still be a small amount of cooling because the coils
are icy, but with no air flow over the coils, cooling in the
refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to
determine if the problem is with the self-defrosting system. Remove all
of the perishable food from the refrigerator and freezer, turn the
thermostat in the refrigerator to Off, and leave the doors open for 24
to 48 hours. (Be sure to have several towels ready in case the melting
frost and ice causes the drip pan to overflow). This allows the
refrigerator to defrost "manually." When the frost and ice build-up has
completely melted away, turn the thermostat back to a normal setting. If
the refrigerator then cools properly, it indicates a problem with one
of three components in the self-defrosting system:
- The defrost timer
- The defrost thermostat (also called the bi-metal
switch)
- The defrost heater
If it still does not cool properly, there may be a
problem with the refrigerant level or the compressor. You may need to
consult with a qualified appliance repair technician to further diagnose
the problem
Condenser
Self-defrosting refrigerators all have a set of
coils and a cooling fan, usually under the refrigerator, that need to be
cleaned regularly. If these coils get coated with dust, dirt or lint,
the refrigerator may not cool properly. The coils may appear to be a
thin, black, wide radiator-like device behind the lower kick-panel. To
clean them, disconnect the refrigerator from the power source, use a
refrigerator condenser brush (see the Appliance Accessories section) and
your vacuum cleaner to clean the coils of any lint, pet hair, etc. You
may not be able to get to all of the condenser from the front, it may be
necessary to clean the remainder of the condenser from the rear of the
refrigerator.
Tell us news.
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
