20 Most Recent Amana ABB2224DES Stainless Steel Bottom Freezer Refrigerator Questions & Answers
I hava an Amana ABB2224DES
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4/3/2011 5:26:46 PM • Amana ABB2224DES... • Answered on Apr 03, 2011
Amana ABB2224DES fridge freezes everything in the
Sounds like your Temperature Control Sensor has gone bad. Could also be that the door on the duct from the freezer to the fridge is stuck open due to a bad solenoid there.
1/21/2011 2:10:40 PM • Amana ABB2224DES... • Answered on Jan 21, 2011
Not cold in frig
needs charging call HVAC man
11/19/2010 3:37:58 AM • Amana ABB2224DES... • Answered on Nov 19, 2010
Recently, my Amana ABB2224DES refrigertor/freezer
If unit has an ice maker it could be getting stuck
11/19/2010 3:34:28 AM • Amana ABB2224DES... • Answered on Nov 19, 2010
Freezer ices up on normal setting, refrig warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
10/26/2010 12:55:11 AM • Amana ABB2224DES... • Answered on Oct 26, 2010
Have light inside, but the motor is not
replace the rtc overload contactor on the compressor body,it unplugs off the compressor and supplies power to the compressor
2/21/2010 11:22:26 AM • Amana ABB2224DES... • Answered on Feb 21, 2010
Amana abb2224des with Bottom freezer. Just
the least you remove the better.use vacuum cleaner hose to collect s..t (dust) easier than wet cloth.
2/12/2010 12:43:24 PM • Amana ABB2224DES... • Answered on Feb 12, 2010
Amana ABB2224DES Stainless Steel Bottom Refrigerator is war
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
9/3/2007 6:36:05 PM • Amana ABB2224DES... • Answered on Sep 03, 2007
Amana SXD2252 side by side ice maker stopped, now leak on floor
ck here... https://www.appliancepartspros.com/repair-help/amana-refrigerator-sxd22s2w-repair/sxd22s2w-leaking.html But before throwing parts at it give their tech 877# a hollar.. Best to you
9/4/2023 5:56:53 PM • Amana... • Answered on Sep 04, 2023
Amana ARB1917CSR 18.5 Cu. Ft. Plus Refrigerator. What is the HP of my compressor, which Supco relay and run capacitor?
What tends to happen is that service techs have certain common generic parts in their van, and rather than ordering a part to fit and have a return visit, they fit what they have. Parts seem to be readily available. The compressor is listed but no HP Specs. The bottom show another model and that R134A (1/4HP) is different to R134 (1/5 HP). https://www.google.com/search?q=amana+arb1917csr+parts+diagram https://www.google.com/search?q=Tecumseh+TP122AR003B8 ..
7/27/2023 6:43:23 PM • Amana... • Answered on Jul 27, 2023
3answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM • Amana... • Answered on Jun 20, 2023
Possible cause of Amana refrigerator making a constant clicking/noise?
Sharla, It could possibly be the ice maker rod that tells the ice maker whether it's full or not. If it's in the down position it wants to make ice and it'll make a clicking noise. Lift the rod up if it's down. Hopefully this helps!? Best to you.
4/21/2023 7:28:31 PM • Amana... • Answered on Apr 21, 2023
3answers
What year is my Amana refrigerator, Model # ASD2522WRB06?
I'd like to know how you determine the age based on the info inside my Amana. I double checked the numbers. Model AFI2538AEB4 Serial KY2886165
3/4/2023 11:22:10 PM • Amana... • Answered on Mar 04, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
  1. Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
  2. Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
  3. Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
  4. Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
  5. Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM • Amana... • Answered on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM • Amana... • Answered on Jan 14, 2023
Where is the defrost timer located in Amanda Model SXD2252W
check to see if defrost fan working
10/19/2022 2:58:33 AM • Amana... • Answered on Oct 19, 2022
How do you remove the light cover from amana refrigerator model arb2107?
I have an Amana AS12575GRB01, the cover to the light bulb on the fridge side is mounted on the top inside back right corner. Having problems removing it
9/8/2022 1:07:18 PM • Amana... • Answered on Sep 08, 2022
I have an Amana Fridge (model ABD2533DEW) that makes a buzzing noise for about 10-12 seconds and then clicks off.
There are several videos on line about buzzzing fridges. This is one https://www.youtube.com/watch?v=O2TVZazGLJ0
6/29/2022 2:41:17 PM • Amana... • Answered on Jun 29, 2022
Amana ABB2224DES Stainless Steel Bottom Freezer Refrigerator Logo
17 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
light inside but motor not r n
  • Refrigerators
