20 Most Recent Gigabyte GA-8I915ME-G Motherboard Questions & Answers
0answers
Drivers Windows 7
Be the first to answer 1/25/2014 3:21:13 AM • Gigabyte... • Posted on Jan 25, 2014Be the first to answer
Pci to micro channel bridge
Hello download the drivers here:http://ee.gigabyte.com/products/page/mb/ga-8i915me-g/download/Click on the link, to the right, for download.Good luck
1/22/2013 2:35:02 AM • Gigabyte... • Answered on Jan 22, 2013
No sound problem
Search Gigabyte GA-8I915ME-GDownload and run.http://www.gigabyte.com/products/product-page.aspx?pid=1926#dl
11/2/2012 5:25:17 AM • Gigabyte... • Answered on Nov 02, 2012
Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.Now boot into Windows and click control panel.Double click Administrative tools and double click Computer Management.Left on screen: Select Disk Management under the heading, storage.Here is where the hard drive should be detected. If not present click action, followed by refresh.Now select your new drive and format it using NTFS.Take care!damnor01
6/9/2012 1:33:12 AM • Gigabyte... • Answered on Jun 09, 2012
Can i use gigabite ga
NO!
Only DDR 333/400 works on this board
8/17/2011 9:13:12 PM • Gigabyte... • Answered on Aug 17, 2011
Is gigabyte-81915me-c motherboard support 1 gb
This is the RAM specs for this motherboard.
Memory
  1. Type: Dual Channel DDR 400/333
  2. Max capacity: 2 GB
  3. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
6/21/2011 10:19:43 AM • Gigabyte... • Answered on Jun 21, 2011
0answers
Sir am not able to
http://download.gigabyte.eu/FileList/Driver/motherboard_driver_chipset_intel.exe
if this info is useful to you please vote for me
2/27/2011 6:08:59 PM • Gigabyte... • Answered on Feb 27, 2011
Required all driver for win xp
You can download your required drivers from the links below..;
1. gigabite ga-91815Me-G motherboard drivers gigabyte.com
2. gigabite ga-91815Me-G motherboard drivers gigabyte.eu
Open the links and select the nearest download location... (like Asia, China, America, Europe..etc..)
Good luck.
Thanks for using FixYa.
6/24/2010 5:57:12 AM • Gigabyte... • Answered on Jun 24, 2010
Gigabyte GA-8I915ME Beep codes
Hi David,
Do you have your manual for the motherboard?
If no? You can down load it from Gigabyte.
Click on this link:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1926
Go to page 76 for the bios beep code description. Your bios is AMI. Click the next link for AMI beep code error descriptions:
http://www.bioscentral.com/beepcodes/amibeep.htm
There are two possible troubles. 1) the first bank of memory has a problem. You can download a program that can test your memory without going into windows. Program is free & allows you to create either a bootable floppy disk or a bootable CD-ROM disk. Click here: http://www.memtest.org/ Scroll down the site until you see, Memtest86+ V2.11. (V2.10)
If your manual is 100% correct than the error is fatal. AKA not repairable but I would suggest you try the above first before tossing the board.
Best of luck David!
Having trouble, post here.
Mike
4/3/2009 4:22:06 AM • Gigabyte... • Answered on Apr 03, 2009
No display by gigabyte GA8i915me motherboard
It sounds like your CPU might be overgeating. Check the CPU heatsink fan to see if it is spinning. Also, make sure that you clean out any dust, as this can lead to overheating also.
3/9/2009 8:39:53 PM • Gigabyte... • Answered on Mar 09, 2009
4answers
I dont able to format my pen drive when i open it
Hi
First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
Thanks for using fixiya
Rupesh Kumar
12/18/2023 12:36:15 PM • Gigabyte... • Answered on Dec 18, 2023
Why my Gigabyte GA945GCM-S2C board GPU heat instantly
If it is not an accumulation of dust and if your fans are working properly and your ventilation is not blocked, that there was not a built-in cooling system for this integrated part makes me wonder what is going on. One would have thought it suggested such was not necessary. How old is the thermal paste in the computer? I would replace that before trying more desperate measures. Rather than presume the fan was working, I'd make sure that it was. Here are some causes and fixes: https://www.onecomputerguy.com/gpu-overheating/
10/15/2023 4:39:50 PM • Gigabyte... • Answered on Oct 15, 2023
Hey, I own gigabyte W566N
1/5/2023 3:23:38 AM • Gigabyte... • Answered on Jan 05, 2023
Ati radeon hd 7770 problem
no PC told at all no OS told either. sure a DESKTOP sure. no monitor told nor cable used, VGA, DVI,hdmi, DP i can not see your near black screen at all. cold booted is the PC splash screen dead./? all bios screen dead and all BIOS works even with HDD missing. idle black is sleep mode, a USA law mandates that. iof we do not like sleep mode we disable it in power settings CP CP means control panel this must be your first PC ever? and all go to sleep ,go to walmart see them all in sleep mode now, yes, a USA law called Energy star laws. and all wake up on demand new , unmolested. wiggling the mouse or hammering the space bar ends sleep but not if (again) power settings has USB going to sleep too. why post lacking Pc makers name and OS.windows what gee vast persons on earth ugraded w7 top 10 and now this fails. due to , PC maker told you , no w10 support in this secret PC 4 decades of 100,000 models of PC I can no no guess blind./ Radeon hd 7770 card and 80watt card in fact, oops.????? is this real ATI/AMD card or any of the other 12 makers of cards. ??????????? no full card number told and guess what the watts matter. 250watts is smallest watt PSU, or more if PC is loaded out like mine with 2SSD and 4 SSD and 1DVD and 1 Blue ray and max ddr and more. Power is first after fit, and yours fits so power is next PSU watts and what the card needs let me see that. all hits on this card show it crosses the magic 75watt rule for PCi-2 power of 75watts, and card is 80watts and more dynamically so they maker of the card has a 6 pin 12vdc aux jack that can not be ignored or the card fails, so is that wired up? as it must? yup top rear of card 6 pin aux power in black , steathy that, hard to see at 1st glance but 80watt cards need it, that and even 300watts cards are sold. does your card have red fan. see what I mean buy 12 maker of cars all with AMD GPU. the cards all have tag called the SKU tag or full model told for GPU speed and vram sizes and more, lots more. https://search.brave.com/images?q=%20Radeon%20hd%207770%20card# I have boxes full of old GPU cards here, stored. some need 500watt more PSU to even begin any 3d mode. only the SKU matters, wiki SKU. and what PC this is and what PSU wattage and if said PSU has the 2 AUX CABLES WITH DUAL 6/8 Plugs, (PCI-12v) marked. if not we can do adapters easy. ask
6/4/2022 4:14:14 PM • Gigabyte... • Answered on Jun 04, 2022
My soundcard is not working while using 8vm533m-rz model gigabyte mother board in windows 7
so the PC mobo has and addin, PCI card sound"? 2004 PC mobo relic, now and 13yo to you. no card told. (fail)(buy only w7 allowed card if must) you did say CARD so means NOT ON-BOARD sound chip. relic P4 PC. mobo v1.0 mobo? this trash mobo uses EOL DOA, via chipsets, that do not allow w7 Integrated Realtek ALC662 audio CODEC chip this chip set is dead too, from maker realtek. if you knew that, and added a secret sound card. this mobo only does windows 200o to XP says so on page one at gigabytes this mobo. so w7 does not belong hear unless replacing every thing there that fails 1 by 1, , pain. ive done this vast times, for folks willing to. last xp driver is here for realtek https://www.gigabyte.com/Motherboard/8VM533M-RZ-rev-10/support#support-dl-driver as a rule only this OEM maker PC can make there sound chips work (as a team of parts) not simple as many think, even has mixer chips and more, all custom to maker. yes cards work better, on this mobo the VIA chip and codec chip must work or sound will be dead. and is common this. lacking no vista driver up, ever/ this mobo has no SATA ports nor any PCI express card slots at all. and finding PCI (non express) cards that can run w7 can be hard. for sure now. yes possible, with careful searching specs of relic PCI cards. also the VIA chip dead makes The ethernet port dead too. and usb dead and IDE drives dead,vista up. never buy VIA chipped mobo. or pain is all there is. no drivers.
6/4/2022 2:16:57 PM • Gigabyte... • Answered on Jun 04, 2022
Gigabyte GM-M5050 not connecting to laptop.
it is only a USB mouse and works on any pC really. w7 needs no special driver for this mouse ever, it uses PnP, plug and play and the internet must be active and working for PnP to work is it? not told that. your failed computer is all messed up with w7 even infected monza is w7, 2012 made (year) the usb ports are first not mouse the device manager must show all USB ports have good drivers, and you test them using a USB stick of thumbdrive memory to be sure they do work, and if does good or use USB keyboard to test usb ports all if all that works then the mouse is tried. and internet connected and the mouse to when connected must show up in device manager. and actually function/
6/4/2022 1:34:15 PM • Gigabyte... • Answered on Jun 04, 2022
Hi i have a gigabyte
talk to gigabyte.com is the cooler not from gigabytes is that it? so is this below? i guess you meant Model# GZ-FW1CA-AJS go back to air or upgrade to far better cooling this is not. cheap cooling is no good. will not last. also above is know for bad corrosion inside, rule #2 buy cooling only from makers that see spare parts for it. or is doomed. the manual shows no parts list for sure water level so needs new water tank I guess, why not ask maker for support no PC store sells parts for this custom case.(turn key is seems) or defeat that switch and just look at level at step 1 , before turned on. (that is what I would do, but sure back to AIR
6/4/2022 12:43:46 PM • Gigabyte... • Answered on Jun 04, 2022
Gigabyte GA-8I915ME-G Motherboard Logo
21 questions posted
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gigabyte Computers & Internet
Most Popular Question
gigabyte 81915me c motherboard support 1
  • Computers & Internet
