20 Most Recent
Foxconn 760GXK8MC-RS Motherboard Questions & Answers
Hello i would like advice
Probably have to stick with SATA II for HDD but you could probably use more space! You didn't say what you use your computer for but ... What you really need is much more RAM 'course it will be a LOT more expensive now than even a few months ago...Buy the same RAM as you currently have but if you are using a 64bit operating system use at least two 4GB sticks two 8GB sticks better still... HTH Alan
9/14/2017 8:48:01 PM •
Foxconn...
Answered
on Sep 14, 2017
Just a beep all the
if it work but you hear a beep try another kayboard or take the mouse and KB off and swich on the pc if no beep that mean KB or mouse is bad change ,
if the pc not work that mean aproblem with vga card or ram
if you see that is helpful plz don't forget to vote me
best regards
4/21/2011 3:13:06 AM •
Foxconn...
Answered
on Apr 21, 2011
Had to put my motherboard
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
2/17/2011 9:43:48 PM •
Foxconn...
Answered
on Feb 17, 2011
Its rpm = 0
check if its connected correctly adn if it cannected properly then i think u have to replace it
1/29/2010 8:32:58 AM •
Foxconn...
Answered
on Jan 29, 2010
Installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
3/12/2009 10:47:01 PM •
Foxconn...
Answered
on Mar 12, 2009
HI-SPEED USB DEVICE
Here is a link to your manual
On pg 31 of your manual what are the BIOS settings displaying?
On pg 33 you want to make sure the SIS USB is enabled and that the USB 2.0 supprt is enabled.
If you have the CD that was included with your motherboard, there is a 2.0 driver that needs to be installed as well.
7/17/2008 5:23:15 PM •
Foxconn...
Answered
on Jul 17, 2008
Video card troubles
Hi, with my own Foxconn mobo [661FX7MI] I had to run the installation disk that came with the motherboard and reinstall the AGP driver. Then run the AGP card driver [ATI] disk.
Regards mistyman
10/22/2007 1:30:15 PM •
Foxconn...
Answered
on Oct 22, 2007
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM •
Foxconn...
Answered
on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM •
Foxconn...
Answered
on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like
others were sold as DIY from foxconn direct sales.
did you lose the PC case?
or buy just a mobo , raw?
front panel pinouts you meant but failed to say just what:?
foxconn (channel) went dead. 2012
the maunuls where there, then, and now all gone. they are gone.
all is gone but the echo, (waybackmachine)
old
Intel P55 / H57 chipset
age ,2009, and lost manuals, are are not, lost 2012 year when the went dead.
no can find, me....
5/13/2022 11:50:16 AM •
Foxconn...
Answered
on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM •
Foxconn...
Answered
on Jan 11, 2022
Bios detection
DON'T OR SAY WHY YOU MUST?
99.9^% DON'T
OR BRICK LIKE MILLIONS HAVE NOW.
today is foxconn day;. and they went EOL , DYI in 2019
no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM •
Foxconn...
Answered
on Jan 09, 2022
Foxconn ml 94v-0 e253117 manual
94v-0 is PCB flame proof spec, certs.e253117, is outside USA, electrical safety certs, both uselessthen land on just ML.,useless too.the mobo I bet has a tag like these, learn to post real sticker tag labels only, not certs painted on the mobo we can not see.andWhat is N15235? (is and electric safety spec #)Often the marking N15235 is mistakenly deemed to be the model number of a mainboard or graphics card, but it's just Foxconn's ACA supplier code number which signifies that the product may be legally sold in Australia.
1/9/2022 11:40:57 PM •
Foxconn...
Answered
on Jan 09, 2022
Tean ml1 94v-0
Tean ml1 (94v-0)
94v0 is useless input, it is PCB burn rate test certs.
what is a TEAN?
ELO TOUCH Main Board LL050 TEAN ML1???? 2003? year?
ELO is where to go not now dead foxconn (DIY) only is dead.
ELO Touch panel. The original touch screen was 996-0484-00, PT1503NT.
its not a PC it is only a monitor
what matters is the PC not told by you nor what OS you run.
or ask ELO for them.
here they are, had to do reverse look-ups on PCB.
https://www.elotouch.com/support/downloads#/
1/8/2022 6:59:59 PM •
Foxconn...
Answered
on Jan 08, 2022
