ASUS A7V8X Motherboard
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with ASUS A7V8X Motherboard?
Troubleshooting and Support
Solved Problems for ASUS A7V8X Motherboard RSS Feed Post a New Problem
Presario SR1030NX - with a ASUS A7V8X-LA...
Hello. I have a Presario that has a ASUS A7V8X-LA motherboard. My problem is that it won't boot. I don't even get a...
1 Solution
Re. cannot install XP need a clean install
Thanks for help, I am using a "For dist. with new pc" disk. I have also tried a XP upgrade disk both genuine...
2 Solutions
processor
I need to renew / update my processor (AMD AXDA 3000 KV4D) can you tell me what in compatabe with a ASUS A7N8X-X Rev...
1 Solution
ASUS A7V8X-X Audio
OS Windows XP. Audio works before. When I downloaded an upgrade to my system drivers and not from ASUS, the audio...
1 Solution
problem with AGP on Asus A7V8X-X
Hi. i'am the owner of A7V8X-X (Bios rev.1010) and graphic card GeForce3 Ti200. Both supported AGP speed x4, but this...
3 Solutions
Asus A7N8X-X (third memory slot)
The above motherboard has 3 memory slots and each can hold 1GB. There are currently 2 identical 1 GB sticks installed...
6 Solutions
Max. AMD for Asus A7N8X-X
I am running a Asus A7N8X-X Motherboard with a AMD 2600+. I can't find my manual. And I would like to know that is the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetVIA Apollo KT400
Compatible ProcessorsAMD Duron, AMD Athlon · AMD Athlon XP, AMD Duron, AMD Athlon · AMD Athlon XP, AMD Athlon
Front Side Bus Speed266 MHz
Technical Features
Expansion SlotsAGP x8 x 1 · PCI x 6
Integrated Input/Output PortsSerial Port x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · USB 2.0 x 6 · RJ45 Lan Port x 1 · FireWire (IEEE1394a) x 2 · Game/MIDI Connector x 1
Storage Controller Type(s)Serial ATA x 2, DMA/ATA-133 (Ultra) x 2 · DMA/ATA-133 (Ultra) x 2, Serial ATA x 2
South Bridge ChipVIA VT8235
RAID SupportRAID 0 · RAID 1 · SATA RAID 0 · SATA RAID 1
Processor
Max supported CPUs qty1
Socket TypeSocket A
Memory
Max Supported RAM3 GB
Memory TypeDDR SDRAM
Supported RAM Speeds400 MHz · 266 MHz · 200 MHz · 333 MHz
Number of Memory Slots3 x DIMMs
Other Features
Package Qty1
Chassis Type1 · Desktop
Other FeaturesChassis intrusion detection
Audio / Video
Audio OutputSound Card · 5.1 Channels · SPDIF out
Video InterfaceAGP 8x
Audio InputSPDIF In
Dimensions
Depth9.65 in.
Width12 in.
Communication
Networking TypeNetwork Adapter · Ethernet, Gigabit Ethernet, Fast Ethernet
Warranty
Warranty3 Years
Supported Models
A7V8X GB LAN, A7V8X/A/L/SAT/1394, A7V8X/GBL/1394/S-REF, A7V8X/LAN/1394/SATA/R133-UAY, A7V8XGBL1394SATAR133
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
Loading problems.
Top Motherboard Experts
map9966
61 solutions
Computer Hardware, Computer Components
Ask Me
Guru
colliewo
26 solutions
Computer Input Devices, Computer Components...
Ask Me
Wiz
Bubbabea
3 solutions
TV and Video, Computer Hardware...
Ask Me
Wiz
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
