20 Most Recent
Bissell 6594 PowerForce Bagless Upright Vacuum Questions & Answers
My problem is that dust
It could be a clog somewhere, a air leak somewhere and/or clogged filters. Cleaning filters does not necessarily mean they are not clogged. They should still be replaced quite frequently.
Hello, my bissell vacuum is
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on how to do proper maintenance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
My Bissell vacuum cleaner won't turn on.
One of the possible causes that your Bissell won't start is that power cord may not be firmly plugged in so you may need to check electrical plug. You may also want to check or replace the fuse or reset the breaker in case there is blown fuse or tripped breaker.
Ava B.
Bissel vacuum will not turn on
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
I have a Bissell powerfoforce
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
How to replace on off switch
have the vacuum disconnect and then get a couple of tools and took the switch and be very careful and then put the new back the same way you took it out.
Where is the reset button on the Bissell Powerforce helix upright ?
This unit does not have a reset button or fuse that is accessible or repairable. If you are referring to the manuals troubleshooting no power, the blown fuse or tripped breaker that is being referred to in the manual is your house hold breaker box and the fuse or breaker that handles the outlet the unit is using.
If your having power issues you should first inspect that all accessible parts are functioning. Such as hoses being closed, dials resting in the set positions, wand locking. Also if visible the sensors that are keeping tabs on each part. Another issue may be that the cord had been kinked and has shorted out, one possible way to check this issue is: if the unit powers up only when the cord rests in certain positions.
If this was recently purchased the warranty is for one year. A ship repair cab run $35 to $100+ you will have to call around. Or have a handy family member you with it.
Being these machines can be found $50 to $75 a replacement would probably be your best bet.
How do I replace a power cord on hoover u6311?
Heat shrink wrap not electrical tape since it can peel away
New cord longer is better in my opinion
Wire cutters
Or Wire extension or splice adapter
If the wire is brown copper use a new copper wire if it is silver aluminum use a new aluminum wire.
