20 Most Recent Polaroid Wireless Performance Battery Grip for Nikon D5100 Digital SLR Camera Questions & Answers
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
11/29/2012 11:57:55 AM • Polaroid... • Answered on Nov 29, 2012
Polaroid iSO48 Waterproof 16MP 4x Optical Zoom Digital Camera. I have an issue I think, when I watch a video that was recorded with the camera? It sounds like a constant "pip pip pip".
Question edited for clarity. This noise is more likely coming from the whatever is playing the video that than the camera recording itself. I have seen on old VCR machines. Play the video on something else to test.. https://www.google.com/search?q=Polaroid+iso48+video+makes+noise ..
2/25/2024 11:22:01 PM • Polaroid Cameras • Answered on Feb 25, 2024
Polaroid PDC 4055 Digital compact Camera. It won't display what's on the lens and keeps flashing a red light.
Question edited for clarity. Did you put in brand new certified fresh NiMH or Lithium Batteries? Opening the lens and powering the screen take the most milli-amps. The red light flashing is likely telling you the battery is flat. Did you check the manual? It has a Power LED. https://www.manualslib.com/manual/131605/Polaroid-Pdc4055.html?page=2#manual https://www.google.com/search?q=Polaroid+pdc+4055+battery https://www.google.com/search?q=Polaroid+pdc+4055 ..
9/10/2023 5:52:46 PM • Polaroid Cameras • Answered on Sep 10, 2023
I need a manual for my Polaroid i20x29
7/26/2023 1:30:04 AM • Polaroid Cameras • Answered on Jul 26, 2023
How do I review the sd card on Polaroid i534
4/13/2023 7:49:38 AM • Polaroid Cameras • Answered on Apr 13, 2023
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
2/5/2023 6:29:22 PM • Polaroid Cameras • Answered on Feb 05, 2023
Polaroid Land Player. The cassette in it will not eject.
Polaroid Land Camera or Polaroid Polarvision Player? https://www.google.com/search?q=polaroid+land+player%2C+cassette+won%27t+eject If it is Polarvision, it is an antique from 1977 and really shouldn't be used. https://www.google.com/search?q=polaroid+land+player&rlz=1C1QJDB_enCA643CA644&sourceid=chrome&ie=UTF-8 ..
1/11/2023 11:45:53 PM • Polaroid Cameras • Answered on Jan 11, 2023
Can't Find Polaroid iE826 Battery Replacement
Batteries do seem to be available and they do look like phone batteries. Just make sure the voltage is okay and that the MAh is the same or higher. https://www.google.com/search?q=Polaroid+iE826+battery+replacement ..
12/21/2022 7:16:19 PM • Polaroid Cameras • Answered on Dec 21, 2022
Reset date on iE826 Polaroid
See previous response to the same question
10/21/2022 6:56:54 PM • Polaroid Cameras • Answered on Oct 21, 2022
How do I connect my Polaroid speaker to sd card
First check whether your speaker has a slot for SD card if it is present then plug the SD card into the slot
1/16/2021 7:14:09 AM • Polaroid Cameras • Answered on Jan 16, 2021
Polaroid iS126 rapid battery drainage
This camera is known for that. Save your money and buy something with rechargeable battery
2/19/2020 2:21:49 AM • Polaroid Cameras • Answered on Feb 19, 2020
My Polaroid a700 camera wont take pictures. I press the take picture button but nothing happens. it has new batteries installed.
Is the memory card full? If thats not the problem, take the card and batteries out so it will reset, Make sure it is set on the correct mode. Then try again.
11/21/2019 12:16:49 PM • Polaroid Cameras • Answered on Nov 21, 2019
I've recently purchased a Polaroid iXX090, waterproof camera. It's draining the batteries in minutes! Even when the power is OFF, it drains the batteries. Am I doing something wrong?
First thing is to check that the batteries are correctly inserted. If they are, then it seems likely that you are not using sufficiently high powered batteries - are you using those recommended by the manufacturer ?
10/3/2019 10:59:35 PM • Polaroid Cameras • Answered on Oct 03, 2019
I received my iXX090 20mp polaroid underwater camera. I can't close the battery compartment after I finally got it opened
When mine wouldn’t close it is the battery is not in right. Hope this helps.
7/25/2019 5:02:34 AM • Polaroid Cameras • Answered on Jul 25, 2019
Polaroid Wireless Performance Battery Grip for Nikon D5100 Digital SLR Camera Logo
1 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
Polaroid Cameras
  • Polaroid Cameras
Most Popular Question
adding grip nikon d5100 solve problem
  • Cameras
