20 Most Recent
D-Link DI-714P+ Enhanced 2.4GHz (802.11b) Wireless Router Plus Print Server (NTRTDLDI714P) Questions & Answers
How do i get link from tv
If the new router is using a different security password than the old router, you will have to change the password on the Roku to reflect this.
Not working no channels
Read the manual first. If not, try to reset the device. wifi may have been disabled because the older router use older wifi technology...Or it is dead... Time to get a new one....try kijiji... get a newer one for less than the price of dinnner at restaurant...(minimum 802.11n)
Trying to link my roku
trying to link my roku . can not find where to enter my code. went to roku.com/link. web page could not be found??
Help!!!!!!!!!!!!!!!!!!!!!!! with wireless router/modem
You will get an activation code from Netflix once you have paid or use the 1 free month. You need to go to Netflix.com to do that. Once you have it then select the Netflix service on the Roku and an onscreen keyboard will pop up. Enter the information it wants and you will then be able to watch.
Cannot find where to put in code to activate reset of roku
Connect the RokuOnce you see the Roku box's welcome screen, press the "Select" button on your Roku box's remote control.Select the type of network connection you have (wired or wireless) on the network screen, and provide the necessary information that applies to your network. Once a network connection is established, you should see the activation screen with an activation code.Visit the Netflix activation website on your computer (www.netflix.com/activate) and log in to your account if asked to do so. Enter the activation code on your television screen into the text box on the activation page. The Roku box will now activate.If you need any kind of technical assistance you can contact support cell at
http://www.vtechsquad.com/
Can't connect to localnetwork
Select your network , enter your password --- then ok to connect - upon it failing to connect to local network -- do the following - press home button 5 times, fwd button 3 times , revs button 2 times - takes u to a sub menu - select update software --- after completed - follow steps on screen & connection should work -- if not then press home button 5 times , fwd button, play button, revs button , play button, fwd button -- sub menu opens select disable ping - then do setup - and connection should occur
