20 Most Recent
D-Link 802.11g 108Mbs Cable/DSL Wireless QoS Router (NETWDLDI724U) Questions & Answers
How do I block others from using my router without
You can do MAC (ethernet) address filtering. You can set it to allow only specific MAC addresses to be granted access. For Windows PCs, you can get the MAC adress by firing a command prompt and typing 'ipconfig /all'. For WM, go to 'Start > Settings > System Information' (or something equivalent) select the network section and take note of the Wi-Fi card's MAC address. Anyway, with the MAC adresses of all the devices you want to grant access to your network in hand, navigate to its Web Utility (if it has not been changed before, the IP address is usually set to either 192.168.0.1, or 192.168.1.1, or 192.168.2.1). There, under the security section, you should find the MAC address filtering function.
Please, let me know if you need further details.
Regards,
Carlos
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Help finding out my lost Network Key for an SMC Network router
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address
it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/
try
Username:
cusadmin
Password:
password
IP Address:
192.168.0.1
http://www.cleancss.com/router-default/SMC/SMC8014WG
if you get into it look up wi fi security to find out the wep key or wpa key
How to Contact D-link Support Australia?
At D-link, we understand the necessity of 24/7 need for an internet connection to connect you with the outside world along with providing you with optimum results as well. So, if you are facing any technical issues in your router and unable to solve it by yourself then with the tech support you can ask our experts. We will provide you Toll-Free Dlink Support Number Australia +1 888 597 3962 and online live chat so that you can reach us any moment according to your convenience.
The well-experienced and highly motivated technical teams with their years of experience at
D'link Tech Support will patiently listen to your issue and provide you with an efficient solution. You can contact our specialists at the provided number and our customer care unit will give you the necessary assistance to resolve your issue. Our customer care number is always there to take care of all your Internet-related issues and will provide you with the best available solution to permanently resolve the issue.
We provide a friendly environment and take care of each complaint and feedback to provide better services to our clients. The Toll-free Dlink Helpline Number Australia +1 888 597 3962 and help centers are available 24/7 to assist our customers and free you from your distress of the web connection of the modem and the router. At Dlink, each customer is like a member of our big family and we love to get feedback from them. So, whatever be the need we are there to serve you the best we can.
For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support.
More Info -
https://www.quickhelps.co/phone-number/d-link/
